Results 1 to 10 of 15
Thread: Bathroom Shelves
    9,077
    Bathroom Shelves
    LOML has a double sink vanity area between the tub/shower area and the bedroom. Storage is at a premium in this spot. There is a funky shaped niche that I have been planning on stuffing a shelf unit into. I was waiting for a design to hit me that was not too heavy for the tight space but sizable enough to provide enough shelf space to make it worth occupying the space. Shooting for something like this . . . .
    The bandsaw is a perfect way to rip large planks like this red oak (her bedroom is done in red oak and she would not be talked out of continuing this SoCal tradition into the bath):
Name:	1- deb shelves rip.jpg
    This shows the difference in the sides required to fit the awkward space:
Name:	2- deb shelves sides.jpg
    Face Joint, edge joint, cut to length:
Name:	3- deb shelves face joint 2.jpg
ID:	40429Click image for larger version.
Name:	4- deb shelves edge joint.jpg
ID:	40430Click image for larger version.
Name:	5- deb shelves milled side.jpg
    The sled once again proves its worth:
Name:	7- deb shelves sled.jpg
    Tape the two sides and cut the dado's for the shelves:
Name:	6- deb shelves dado cut.jpg
    There will be a decorative curve at the top and bottom of the sides. I am goung to try to echo this curve on the shelves to transition from the narrow side (for doorway clearance) to the wider side (that butts up against a support pillar):
Name:	8- deb shelves ready4curves.jpg
    9,077
    Tape the shelf blanks together for a gang-cut of the transition curve:
Name:	9- deb shelves gang cut-2.jpg
ID:	40439 Click image for larger version.
Name:	10- deb shelves gang result.jpg
    I need to make the back cleats for hanging this piece and the receiving notches for them. Then its time for some sanding, some BLO and probably (dare I say it) some poly.
    17,475
    shelves are looking pretty good glenn but that door in the back ground whats up with that ???? did you make it as well?
    9,077
    The door is a fix job for LOML. She wants to milk one more winter out of it before she gets a new one. On the upside, the fix went well and the door works great technically. Looks-wise, it has about had it.
    Elgin, IL
    442
    Looks real nice Glenn. I like your trick with tape, I never thought of that.
    Randy
    9,077
    Hanging Cleats and Notches
    I milled out the cleats and then used them to measure the notch size. Clamped them down as guides and used a pattern bit in the Colt:
Name:	11- deb shelf Cleat prep 1.jpg
ID:	40441Click image for larger version.
Name:	12- deb shelf Cleat prep 2.jpg
ID:	40442Click image for larger version.
Name:	13- deb shelf Cleat cutout.jpg
ID:	40443Click image for larger version.
Name:	14- deb shelf Cleat notch done.jpg
    Now, a little finish sanding, tape off the parts that get the glue and do some pre-finishing with the BLO:
Name:	15- deb shelf taped.jpg
    10,604
    I like tha tape trick too. Can't believe I've never thought of it
    You have the cleanest shop I've seen
    9,077
    You notice I only show the top of the bench (recently brushed off) and lord knows what is stacked up behind me(?). Just like the slight of hand magician, its all in the act of misdirecting the audience
    9,077
    For the sake of getting from SketchUp to installation . . .
    Here's the color matching trials. Got the nod from LOML on the match.
ID:	40618Click image for larger version.
    I'll end with a shot of the actual installed spot at her house in a couple days. This "propped in the door" shot gives you the general idea. Nothing fancy, just needed something with a light-weight look that wasn't too institutional looking but had a lot of bang for the real estate available.
ID:	40620Click image for larger version.
    9,077
    LOML went back to work so I was able to install this while she was out. It's her B-day so she'll see it when she gets home and goes to get ready for her B-day dinner tonight. You can now see the reason for the odd shape.
    Attached Thumbnails Attached Thumbnails 21-Deb-bath-cab-hung.jpg   20-Deb-bath-cab-hung.jpg
  1. Plastic Shoebox Shelves
    By glenn bradley in forum Shop Tours
    Last Post: 11-11-2012, 09:06 PM
  2. New Sake Fridge Shelves
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 06-21-2011, 10:24 AM
  3. Making Bi-plane shelves for and with my grandchildren
    Last Post: 02-03-2008, 07:07 PM
  4. Wardrobe shelves
    By Yann Arbour in forum Carpentry and Construction
    Last Post: 04-27-2007, 07:51 PM
  5. Floating Shelves
    By Bob Spare in forum General Woodworking Q&A
    Last Post: 03-24-2007, 02:38 PM
