Results 1 to 6 of 6
Thread: Vacuum Chucking
    Kaneohe HI.
    70
    Vacuum Chucking
    Has anyone have any input or used this Vacuum pump or used it for reverse chucking.? It's on sale at Harbor Freight, not much off but better than none at all. It's a US General 2.5 vacuum Pump.Your comments greatly appreciated.:
    Honolulu, Hawaii
    1,103
    Vacuum Chucking
    Hi John. sending P/M.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    4,553
    I hope they are OK I bought one awhile back but havent had a chance use it yet.
    Dec 2009
    Madison, WI
    206
    I've seen folks mill aluminum with nothing but a shopvac (running continuously) to hold it in place. I'm not sure how you'd do this with a spinning lathe, but it does seem to work well.
    Rhode Island
    800
    Joe,
    Check out this you tube video by Bob Hamilton. About how he uses his shop vac as a chucking method. He's a valued member of WR Vaughn & Stu also know him.
    http://www.youtube.com/watch?v=YBgGm7xIfQ0
    Apr 2008
    Texas
    199
    There are several people that have that pump and say that it works fine. I would prefer a little extra CFM but it might work just fine.
    A Vacuum can work pretty well. You just have to have a larger chuck and a good seal because the Shop Vac does not pull as much vacuum and it leaks quite a bit. The adapter that Nova sold was always intended for a shop vac. Also with most vacuums you need some sort of bypass air or you will burn up the unit. I think you can get by without bypass air on the Festool and Fein vacuums because their motors are not cooled the same way but I would check with the manufacture before you do that.
    Good Luck
    Alan
  1. Need help - Chucking my chuck
    Last Post: 02-08-2013, 07:10 PM
  2. Vacuum Chucking a Bowl
    Last Post: 11-07-2008, 11:19 AM
  3. chucking: innie vs. outie
    By Mark Kosmowski in forum Turning Tool Questions and Show & Tell
    Last Post: 06-02-2008, 02:41 AM
  4. Oneway Live Center & Vacuum Chucking
    Last Post: 05-18-2008, 02:36 PM
  5. Vacuum Rig
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 09-14-2007, 09:00 PM
