Results 1 to 10 of 13
Thread: Outfeed table help, please
    North West Indiana
    6,098
    My question concerns the table behind the table saw, the table the cut material moves onto past the blade. So my questions get answered, I think I will ask the questions numerically. I have a few, they all have a reason.
    1. How long is your out feed table past the table saw?
    2. What is your "ideal" length for an outfeed table if it is different than your answer to #1?
    3. What is the width of your outfeed table? (same width as table saw? same width but offset from table saw, wider on one side of the blad than the other for some reason or other).
    4. How important do you think an outfeed table is? (very, slightly, not important)
    5. What is the distance from your saw blade to the nearest obstruction?
    6. Which side of the blade do you do most of your standing/feeding wood in from?
    7. Any other information you think relavent that I have overlooked would be appreciated.
    I am in the midst of a quandry on my outfeed table. Your answers may sway my decision one way or another, also may just muddy the waters more! I will withhold my thoughts until I hear from you folks and weigh the answers. Please do try to read into my questions and provide your input. It will be greatly appreciated! Thanks.
    Jon
    Quote Originally Posted by Jonathan Shively View Post
    I don't have room for an outfeed table. Wish I did.
    Probubly 6 ft.
    I think 24 " work.
    Since I don't have one I guess not that important. I do have a dead man I use.
    Depend if I have the saw pointed towards the wall or the driveway
    Neither side it depends on the cut
    I'm not much help am I..
    I guess I am not qualified to answert this one..
    My table is 4' x 6'. I have enough room in front and back of the saw to rip 8' long plywood sheets and about 6' to 7' to the left of the blade for crosscuts. My out feed table also serves double duty as an assembly table.
ID:	40946Click image for larger version.
ID:	40947Click image for larger version.
    I also put lockable castes on the table to move it around.
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    My outfeed table is 4'X8'. My saw is a left tilt so the left side of the table lines up with the left side of the saw. The table also serves as my work bench. Since I got a new saw and it is 1 1/2 lower than the table I had to block up the saw. I am thinking of rebuilding the table and make it 6'X6' as I want to get a 50" fence for my saw. Right now I have 6' to the left of the blade, 12' in front of the blade, and 12' after the blade.
    Apr 2009
    Remlap,Al
    87
    five feet so a full sheet of ply wont fall or rise off the blade
    same as 1
    just as wide as the saw and the table to the right, i have 53"cap.
    i would say must have, i rip sheet goods and need the support.
    nine foot to a work table that is 1/2" lower than the saw. can rip 14' if needed
    behind and just the other side from the fence.
    dont forget the dados for the sled you will use two days after you build it and forget to cut them in the first time.
    if you look at the pics of my shop you can see my outfeed table
    NH
    4,005
    That would depend on the projects. If I did a lot of pass doors I would go 6 feet or so. Cabinet door and cabinets 4 or so would do the trick. I would say that you want the table to extend to a point that 75% of your project is on the table. Oh I don't have a out feed table.
    2. What is your "ideal" length for an outfeed table if it is different than your answer to #1? see #1
    3. What is the width of your outfeed table? (same width as table saw? same width but offset from table saw, wider on one side of the blad than the other for some reason or other).Your out feed table should support the work in a manner that it can not tip side ways off the table. If your saw can rip 50 one way and 20 the other and that's what you do a lot of than 75" or so should do it. Remember you have to support the cut off too not just the keeper.
    Well I don't have one. But I would if I had space to burn.
    My saw moves. But if I where to bolt it down and had the space. I would shoot for 18 feet on each end.
    6. Which side of the blade do you do most of your standing/feeding wood in from?I tend to be to the opposite side of the blade the fence is on. Most of the time that would be left of it.
    7. Any other information you think relavent that I have overlooked would be appreciated. The only thing I would add is that if you bolt your saw down try and aim it so you can open doors or windows to feed long stock through it. Door on the in feed and window on the out. You can make some thing up across the window for stock support. I would want to keep the ends of the saw clear too.
    Stupid hurts.
    2,784
    a) The actual outfeed table is 27 X 70 1/4" The contractor saw will double as an outfeed for sheet goods for the new saw, and is 27 X 80 1/2"
    a) I'd say 90". But 70 is fine.
    3. What is the width of your outfeed table? (same width as table saw? same width but offset from table saw, wider on one side of the blade than the other for some reason or other).
    a) Ideally, the width of the saw. Having the set up I have now with 2 separate outfeeds, the smaller width works fine, just has a gap in the middle.
    a) VERY
    a) 9 1/2'
    a) If I'm doing a rip, I'm on the right side of the blade. If doing a crosscut, I'm on the left side.
    7. Any other information you think relevant that I have overlooked would be appreciated.
    a) You basically want to be able to control the wood you are cutting as it leaves the back of the saw blade. If you only cut short pieces, you won't need the extreme length or width for your outfeed table. If you cut sheet goods, you don't want to have to try to catch the wood as it falls...this could (WILL) create a chain of events you don't want to happen!!!!!
    Hope this helps! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    10" gap to allow DC hose access then 24" of table top with miter gauge slot dados.
    Current one handles 98% of what I need. Roller stand handles any long rips, I should mention I use almost no sheet goods.
    60" wide about centered; 12" of wing extends beyond to the right and about 18" oe RT top extends beyond to the left.
    Wouldn't be without it.
    Which direction? 40" to the right until the vertical mast of my overarm guard, 10 feet or so to the left till I hit the wall, 17' to the front till the workbench (which I could probably clear if I had to, in front of the blade there are 55" till the rollup door; with the door up, I'm not sure how far it is to the neighbors front door across the street .
    I stand to the left of the blade if I am using the fence as this allows control against the fence as well as forward. I generally use the miter gauge in the left slot and I stand wherever gives me the best control when using a sled.
    Tyler, Texas
    336
    I have a Grizzly 1023SLX and the outfeed table is 46" deep. That allows me to rip an 8' piece of plywood without it tipping off the outfeed when pushed past the blade.
    Mine is 74" wide...same width as the TS plus the R/H extension table.
    Very. It really makes life easier in the shop.
    I can move the fence 53" to the right. My planer is about 4' to the left of the saw table. It's 8' from the front of the saw to the jointer and about 10' from the back of the saw to my sink cabinet.
    The left side almost always.
    When I replaced my Craftsman contractor's saw with the Grizzly is when I added the large outfeed table. I really like it. I can use it for assembly, sanding and layout in addition to it's primary purpose...extending the saw's table for safer, easier cuts.
    My shop is 20' x 30' with the TS centered. Although the outfeed table takes up a lot of space, it's not exactly wasted because I store my big shop vac underneath it along with a trash can. I have a 9-drawer cabinet under my R/H extension table that holds TS accessories. The tablesaw with the extension and outfeed tables is definitely the heart of my shop.
    Hope this helps.
    Cody
    Thomasville, GA
    5,992
    I have a four-foot wide table past the cabinet, so it's a total of nearly five feet past the back of the blade.
    My outfeed table works grat for me but, if necessary, I can push nearly eight feet past the blade by adding a couple of stands after the table.
    I have a table system on three sides of my tablesaw. It extends about 40" to both the right and lefts sides so I can support a full 4x8 sheet prior to cutting. Here's the setup.
    Extremely!!!
    Fifty inches to the right where the fence is at its greatest position. Eight feet or so to the left.
    Left to be clear of kickbacks.
    Consider other uses for outfeed/support tables. I have my router lift in my left support table, for instance.
    Inline answers above.
    Bill Arnold
  1. a really nice outfeed table for my TS
    Last Post: 10-29-2012, 04:36 PM
  2. Outfeed/assembly table finished!!
    By Craig Johnson in forum Jigs and Fixtures
    Last Post: 01-17-2009, 02:40 PM
  3. outfeed table miter slots
    By Craig Johnson in forum General Woodworking Q&A
    Last Post: 12-24-2008, 04:57 PM
  4. Project: Outfeed Table
    By Matt Meiser in forum Jigs and Fixtures
    Last Post: 03-10-2007, 07:49 AM
  5. Show Me Your TS Outfeed Table!!!
    By Rob Bodenschatz in forum Jigs and Fixtures
    Last Post: 02-27-2007, 10:55 PM
