Results 1 to 4 of 4
Thread: Solved the New Grinder location problem
    499
    I rebuild the end of my cut-off saw table to create a place to put my new grinder. I also added a small shelf below to hold all my sharpening stuff.
    I put my square mortiser on a out of the way storage shelf since it is rare that I use it. ( That is actually another problem ).
    BEFORE
    AFTER Note top is wider and new shelf.
    Long Hill Township, NJ
    467
    Looks good Bartee! Nice clean setup!
    What do you sharpen with your grinder? I don't see any fittings for a lathe tool sharpening setup (in place). I need to find a home for my grinder and get a lathe tool sharpening setup in place.
    What's in the closet to the right of the grinder? I see the 2 black star knobs and am curious. There is a PVC elbow above the grinder - is that your furnace or Dust Collection?
    Cheers
    Jim
    499
    I know it is overkill, but I will be using the grinder for plane blades and chisels.
    I was very fortunate that between a spif from work and a Xmas gift card I was able to get this grinder. It is a variable speed from 1750 to 3150(?). I really wanted a slow speed grinder, so I was able to get the best of both worlds. This is a very heavy unit.
    After taking the Rob Cosman class I saw things that he did that just made sense. It looks like to the the slight hollow grind you get on a chisel makes since after you put the 2nd and 3rd bevels on the chisel.
    I am building a tool rest that will facilitate put the initial grind on plane irons and chisels.
    Rob Cosman sell the One Way tool holder just for this but it is $60 and I am having fun trying to design and build one. I will definitely post when I am done.
    The thing to the right is my Cyclone enclosesure. Click here if you want all the details.
    You can also get a feel for my shop from this album ( click )
    That looks like a good spot for it Bartee. Room to lay items down, off to the side is strongly lacking in my current grinder spot.
  1. Bandsaw Dust Collection Problem Solved
    By glenn bradley in forum Off Topic Discussion
    Last Post: 09-17-2011, 08:36 PM
  2. New Ceramic Toishi..... Update.... Problem Solved!!
    Last Post: 11-13-2009, 04:59 AM
  3. How I solved my chipped veneer problem
    Last Post: 02-02-2009, 05:32 PM
  4. Drill press problem solved
    By Dale Johnson in forum General Woodworking Q&A
    Last Post: 12-31-2008, 03:54 PM
  5. problem solved
    By Dave Kauffman in forum New Tools
    Last Post: 06-13-2008, 01:40 AM
