Results 1 to 9 of 9
Thread: bed rail fasteners
    Southern Louisiana
    947
    bed rail fasteners
    anyone know how to install these...
    http://www.vandykes.com/product/2058...rail-fasteners
    this wouldn't be my choice for fasteners for a bed but the headboard and foot board are already set up for this type and i am making replacement rails.
    i assume i need a deep slot to slide it in on the end of the rail, then drill holes to set those metal pins thru...or am I just missing it?
    thanks
    chris
    10,604
    That's how you install them
    Southern Louisiana
    947
    thanks bob. how do i make that slot. it needs to be pretty deep...maybe 1 to 1-1/4"
    thanks
    10,604
    I'm sure the experts here will have a better idea but when I had to cut mortises in the end rails of the bed I just made I used my dowel centering jig and drilled a series of holes then cleaned out the cut. I suppose I could of built a template and used my router but I didn't want to take the time.
    17,475
    from what i have seen chris they used a slot cutter the kerf isnt much more than a 1/8" saw kerf. you can position your hooks on the outside to get the pin location its the deep kerf thats the pain.
    Atlanta, GA
    194
    It says they're 3 mil thick (0.003")- is that correct?
    868
    Quote Originally Posted by Charlie Schultz View Post
    I take that to mean 3 millimeters thick. not 3 thou. thick.
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Tellico Plains, Tennessee
    4,353
    My first wife and I had a high dollar bed we bought from Ethan Allan that used those type of bed rail fasteners... it was a pretty bed, but it was a pain in the old pastutty to put that thing together...
    Chuck
    Tellico Plains, TN
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    Quote Originally Posted by Chris Mire View Post
    thanks
    chris
    I would be surprised if newly purchased fasteners would fit the existing pins in the head and foot board unless they were by the same company. But let's say we got lucky and they do fit since we have a slot to work with. And speaking of slots, note the angle of the leading edge of the slot. You may or may not know the purpose of the taper is to draw the rails tight into the head and foot boards so the pins should never reach the slot bottoms. This is why a hammer is often used/needed to disassemble.
    And of coarse this brings up the subject of careful measurement. So if I were attempting this I would probably do a prototype with a piece of scrap. As for cutting the slot with the limited equipment I have I'd probably clamp a couple of hand saws together that gives about the correct kerf , and cut them by hand leaving just a little X-tra wood to sand out by hand .
  1. Toddler bed rail
    By Darren Wright in forum Flatwork Project Showcase
    Last Post: 05-22-2016, 11:53 AM
  2. new type of fasteners
    Last Post: 09-25-2014, 06:05 AM
  3. drawer rail repair?
    Last Post: 01-05-2014, 05:09 PM
  4. Rail and Stile
    By Steve Southwood in forum Designs, Plans and Sketches
    Last Post: 08-09-2011, 08:56 PM
  5. EZ 114 rail system
    By patrick anderson in forum Old Ads
    Last Post: 10-08-2007, 01:05 AM
