Results 1 to 10 of 12
Thread: Larry's Generosity - Big Hickory
    Grand Rapids, MI
    383
    So I have been terribly negligent in getting some nice pieces of hickory turned. It's been almost an entire year since Larry brought me several sweet chunks of hickory. I finally got to roughing out the largest one a few months ago, so here's some pics.
    Of course, I decided to rough out this monster with a nub of a bowl gouge, and I ran out of tool. So I still haven't roughed out the inside. DOH! However, I did finally get a new 3/4" bowl gouge from Doug Thompson....woohoo! But the rough bowl is a block of ice right now, so it may be a while before the rest of it is complete.
    Anywho, here's the beginnings of the largest natural edge bowl I have made to date. It started as a blank that was at least 150 lbs. By the time it got on the lathe it was still well over 100 lbs, and I barely was able to clear the headstock with the bark wings. I actually had to chisel a couple areas in order for it to swing clear.
    The following pics show how I get a huge rough blank prepared for the lathe. I cut a flat for the faceplate by cutting slots with a chainsaw, then knock them out with a chisel. I follow this with a large forstner bit, leveling an area large enough to mount my 6" faceplate to. I also trim it as close to round as possible, again with the chainsaw, then on the lathe it goes. With a piece this heavy, I really wish I had some type of pulley system or winch! After making sure all areas clear the lathe, I bring up the tailstock, and fire up the lathe at 120 rpms or so.
    More pics to follow. Thanks again Larry!!
    Hutch
    P.S. Almost forgot to say that rough blank was about 23" in diameter.
    Attached Thumbnails Attached Thumbnails Hickory 1.jpg   Hickory 2.jpg   Hickory 3.jpg   Hickory 4.jpg   Hickory 5.jpg
    Wow Hutch, that is some chunk of wood!!
    For that kind of work, you really need an Easy Wood turning tool, the Ci1 would be perfect, it would rough that bad boy out in no time at all.
    Keep us posted.
    Cheers
    North West Indiana
    6,099
    Be careful there Hutch. That is one big honking chunk of wood. I'll second the Ci1 rougher. I don't do anything like what you have chucked up, but it is a cutting machine!
    Jon
    Sep 2007
    Plainwell, Michigan
    4,857
    Man that is going to be one monster of a bowl Looking forward to seeing the final piece Good to see ya also Hutch
    Grand Rapids, MI
    383
    Carbide Rougher
    I haven't had an opportunity to use a C1 yet, nor have I seen one used in a demo. I have been wondering how much it may cut down time on a chunk this size. This took me almost 5 hrs of work just to get this far!! (including chainsaw time) But my lathe's drive system is also very inefficient, has belt slipping issues, and really is easy to slow down on a blank this size. 2 hp and a leather belt just doesn't cut it!
    As for danger, it's actually rather safe, mainly due to the way this lathe was built. Don't get me wrong, turning it was a total adrenaline rush, but there wasn't any vibration in the lathe. Ah, gotta love the way things used to be built.......
    Hutch
    P.S. Not much to see here, but I shot this short video before I roughed the outside. Spinnin' Hickory
    30,017
    That's a great-looking piece of wood, Hutch.
    I have, use, and love my Ci1, but for something like this, I'd be starting with the 3/4" Thompson. I prefer to use a sharpenable edge when I'm dealing with bark and all the surprises it can hold. (One rock and the carbide edge is toast.) Once the bark edge is defined, then the Ci1 can speed things up a bit.
    Jul 2007
    Des Moines, IA
    854
    Matt, looking forward to seeing the finished product. That is surely a big hunk of wood.
    Feb 2009
    Whittier, CA, USA
    512
    Quote Originally Posted by Matt Hutchinson View Post
    .... But my lathe's drive system is also very inefficient, has belt slipping issues, and really is easy to slow down on a blank this size. 2 hp and a leather belt just doesn't cut it!....
    Spinnin' Hickory
    What's the history on your lathe? It looks like it might have a story behind it.
    Could you put some sort of rosin on the inside of the leather belt to reduce slipping?
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    30,017
    Quote Originally Posted by Dan Gonzales View Post
    What's the history on your lathe? It looks like it might have a story behind it...
    Yeah Hutch, you should post some pics of your lathe when you get a chance. I remember seeing pics over on SMC when you got it, but I don't think you've posted any here. (Or if you have, I've forgotten.)
    Grand Rapids, MI
    383
    Rosin and Lathe
    I play the cello, and I have often wondered about taking a little bow rosin to the pulleys and belt. I really need to try that, cuz I'm sure it would help.
    As for the lathe, here's the link to my Family posting in the Old Iron forum.
    Rollstone Machine Co. Lathe
    Hutch
  1. Can we help Hickory?!!!!!!!!
    By Mack Cameron in forum Off Topic Discussion
    Last Post: 02-25-2012, 02:23 PM
  2. Large NE Hickory Bowl - Larry's Generosity
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 10-25-2011, 06:08 PM
  3. Larry oh Larry, calling Ambassador Larry!!
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 12-27-2008, 03:58 AM
  4. Hickory HF
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 12-31-2007, 02:25 AM
  5. Hickory HF Vase
    Last Post: 12-27-2007, 04:41 AM
