Results 1 to 10 of 11
Thread: Stains colour
    Sarnia, Ontario, Canada
    55
    Stains colour
    Years ago I used a gel stain on new wood trim to match the old trim that was in the house. Well that gel has disappeared from the stores.
    I have purchased different mahogany liquid stains trying to match the colour...in both water based and oil based they are much to red. I am trying to get a browner colour to the mahogany stain.
    Any ideas how to brown up some of these overly red mahogany stains?
    Thank you
    Rod
    Sarnia, Ontario
    Oct 2009
    Bradford, Vermont
    425
    Mix with "walnut" or "ebony" stain, same brand. You can tune stains to your liking by mixing, as long as they're compatible with each other.
    -- Tim --
    Quote Originally Posted by Rod Upfold View Post
    Thank you
    add some green tint.
    55
    Thank you Guys...much appreciated
    Rod
    Sarnia, Ontario
    Apr 2009
    Outside the beltway
    5,250
    You can always add a little green tint.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    13,357
    I just ordered a 'woodworkers' kit of Mixol tints, thinking it would be handy just for this reason. I'm going to be putting in some trim and will need to make the stain match the blinds we've already put up.
    The kit comes with 10 bottles of colors, and a little color chart to help you figure out the mixes..
    Supposedly the tints and very concentrated and suitable for just about any water or solvent based product out there.
    55
    IT sounds like the way to go...
    Went to Woodcraft website and priced it to me here in Canada...Canadian dollars, transportation, duty and taxes - WOW...doubled the price.
    I guess this will be another incentive to get my passport...I have a place in Port Huron that accepts orders for Canadian.
    Rod
    Sarnia, Ontario
    13,357
    Yeah, I think it was like 41 bucks. I almost went with the 99$ set, but figured this would have what I need.
    I never realized the trouble you guys north of the border had to go through to get stuff from the US. I've ordered some modeling stuff from Taiwan before, and it was relatively painless. But from some of the stories I've read here, getting simple things from the US can be quite a pain.
    stain color
    Thank you
    What kind of stain was it?
    Jan 2009
    Cincinnati
    35
    mixing made easy
    Get some test blocks of the molding in the same species of wood , maybe a length of it take a black marker and make lines on it about 4 to 6 inches apart start with your stain, then add a drop of brown compatible stain , then test , repeat this process until it starts to match , ( keep adding the brown until it matches may take up to an ounce for every eight ounces of original stain or so , make sure you continiously stir the stain once you have a match , so it stays mixed sometime you can use dye stains as well to achieve matches, remeber to start out small to achieve the big picture may take some fusing over but well worth it. Remember also to put your clear finish or top coat on test blocks as this will tend to darken the stain as well. This way once all is dry you end up with definite sample block in the color you want , if not exact try some compatabile color of spray (Mohawk toner) over stain and then topcoat .. I hope this helped!
  1. Removing glue stains from TS???
    Last Post: 07-18-2014, 10:12 PM
  2. removing bug stains in maple
    By Dave Black in forum Finishing School
    Last Post: 12-08-2013, 05:21 AM
  3. Containers for Dyes and stains ?
    By Don Baer in forum Finishing School
    Last Post: 08-05-2009, 03:26 PM
  4. Wenge Stains
    By Tony Falotico in forum General Woodworking Q&A
    Last Post: 01-27-2009, 12:04 AM
  5. Replies: 3
    Last Post: 02-18-2007, 01:04 AM
