Results 1 to 10 of 13
Thread: Shaper vs. Big Router
    Feb 2009
    Whittier, CA, USA
    512
    Hello all,
    I have a question that I hope you can answer or at least provide your opinions and experience.
    Without taking space usage in consideration, when comparing a 1.5 or 2 HP shaper (Jet, Delta...) with a cast iron top to a 3 HP under table router (Porter Cable, Makita, Triton...) are you really comparing apples to apples?
    Assuming you are using equal quality cutters will one discern a finish difference between one or the other?
    The reason I am asking is that I am seeing a few used shapers with multiple knife sets for sale in my area and they are a lot cheaper than a router and lift combo.
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    NH
    4,005
    A shaper is nothing more than a big belt driven router mounted to a table.It has one job and does it well
    Really a router is a hand held tool that over the years has become an under table tool as well, it makes it a more versatile tool. You can get a lot of money tied up trying to make the perfect router and table set up. So it will work almost as good as a shaper.
    It is on the same line as mounting your skil saw to a table to have a table saw but that idea never took off.
    The big thing is space you can't store a shaper on the shelf under the bench. You can do that with a good router and router table.
    If you have the room for a shaper get one. If you have limited space in your shop go with the router table. One last thing is a router on a table will not take years of panel raising or railing making. So if your moving towards being a production shop with these tasks than the shaper is the way to go.
    Stupid hurts.
    17,472
    the only thing i can add to chucks reply is that i wish i had got a shaper before spending the dollars on a table setup..the cutters for a shaper are more pricey but they last alot longer as a rule. and i would say a 1.5 or 2 hp shaper will work circles around that 3 hp router in a table. i now have both and use the table alot and as soon as i can warrant the exrta bucks for the insert style cutters for the shaper i will be ready to play better, one other note if you headed towards building cabinets for a job, your gonna want two machines of some kind to run the cope cuts on the rails and another setup for the stile cut..changing back and forth isnt cost effective..
    yes there`s a big difference in both life of the unit and quality of the cut.
    safety on a shaper can be greatly enhanced with a feeder and the cut quality will increase too.
    just for fun try running a router at full load amperage for 2 hours.......a shaper can take that load for years
    Shaper wins over Router, every time
    Or if space is a problem you can try and find a shaper like we had in the shop I worked in in Baltimore. The cope and stick cutters were on the same spindle and with the flick of a switch you could switch back and forth between them.
    If I had the space, I'd have both
    11,831
    My first thought also. Space. If you have plenty, own and use both. If you don't have enough, routers are a great invention.
    Oct 2009
    Bradford, Vermont
    425
    A shaper is also MUCH quieter than a router... AND generally more dangerous. The cutters leave a much finer surface than router bits do, but they also cost a LOT more.
    That said... I do own a small shaper, as well as four router tables. Each has its place & jobs to do.
    -- Tim --
    NH
    4,005
    http://www.freud-tools.com/freuddoorlip1.html $65.99 router bit
    Item Number Overall Diameter (C) Cut Depth (H) Carbide Height (h) Minor Height (R) Large Radius (A) Angle Shank Diameter Overall Length
    99-001 2" 29/64" 1-1/4" 11/16" 3/8" 7 1/2" 2-3/4"
    http://www.freud-tools.com/freudecdoorl.html $69.99 shaper cutter
    Item Number Overall Diameter (d) Cut Depth (H) Carbide Height (h) Minor Height (R) Large Radius (A) Anble Bore Diameter
    EC-001 2-7/8" 29/64" 1-1/4" 43/64" 23/64" 7 3/4"
    2 bit the approximate same size to do the same job
    Stupid hurts.
  1. Elementary Router versus Shaper Questions
    Last Post: 11-29-2010, 02:01 AM
  2. router bits in a shaper?
    Last Post: 11-20-2010, 03:17 PM
  3. Router vs Shaper question
    By Jeb Taylor in forum New Tools
    Last Post: 11-12-2010, 03:08 PM
  4. Shaper AND Router Table?
    By Allen Grimes in forum New Tools
    Last Post: 05-09-2007, 06:43 PM
  5. Router Table or Shaper?
    By Richard Leshner in forum New Tools
    Last Post: 02-20-2007, 01:18 PM
