Results 1 to 10 of 14
Thread: Grain filler for unusually colored wood?
    Dec 2009
    Madison, WI
    206
    I've been learning a lot about woodworking, but one thing still has me very perplexed: How best to fill in the grain on unusually colored wood, like canarywood or bloodwood. I've tried using a mixture of glue and sawdust as a filler, and it didn't work very well at all. Can someone suggest a good technique for this?
    Apr 2009
    Outside the beltway
    5,255
    Instead of glue, use Lacquer sealer and fine wood dust. in the areas that require special coloring, using the dust from the area you need to color.
    You can also get a natural grain filler and use universal tints also.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    if you`re going to use a commercially available filler err on being too dark instead of too light.
    Apr 2009
    Outside the beltway
    5,255
    Todd even the chimerical stuff you can test and tint to desired colors. But yes darker is better then lighter I agree.
    Dec 2009
    Madison, WI
    206
    Quote Originally Posted by Dave Hawksford View Post
    You can also get a natural grain filler and use universal tines also.
    Like this stuff?
    http://doitbest.com/Main.aspx?PageID...paign=DATAFEED
    I've heard that shellac is the best base coat for a lot of the exotic woods, mostly due to their high oil content. Do you think this would work with shellac as well?
    Thanks for the help!
    Apr 2009
    Outside the beltway
    5,255
    Joe shellac is best used on woods with a high tantic acid content.
    I do not think I would touch any thing that has a short shelf life on line.
    If you are going to work as a finisher, find a product you can work with consistently and stay with it. This way you learn the pro's and the con's of the product, and get a good comparable system from stripping to finishing. The worst thing that can happen in a shop is cross contamination. I will cause you to have ONE HECK OF A BAD HAIR DAY !LOL
    Never tried this myself, but.... Several years ago I read on a forum that this person used Plaster as wood filler (grain filler not patching putty)
    It seems, according to the poster and verified by others, that after dry and sanded, the application of BLO would make the plaster transparent leaving closed pores, smooth surface, and matching color...
    Might try practicing on a scrap piece.
    17,472
    i am no where near as old as you are mr simpson but i have heard the same thing or read it somewhere, but i dont see it turning transparent...if you add water which is clear to it you get white mud, i dont see how BLO is gonna make it go clear..but if i recall they said that the filler took stain to make it appear to be gone.
    QUOTE=larry merlau;198550]i am no where near as old as you are mr simpson but i have heard the same thing or read it somewhere, but i dont see it turning transparent...if you add water which is clear to it you get white mud, i dont see how BLO is gonna make it go clear..but if i recall they said that the filler took stain to make it appear to be gone.[/QUOTE]
    Well thanks for the reassurance of the age differences... I think...
    Like you, I heard it on the Grapevine.... you know, everything you read on the internet, has to be true...
    That is why I said give it an experimental try on a scrap. Who knows
    Nov 2009
    Orange Park Florida
    37
    The info about plaster of paris came from an article in Fine Woodworking mag and that article also mentioned 4f pumice as doing the same thing. I was going to try that but couldn't get pumice anywhere & didn't want to spend for a bag of plaster that I'd only use a couple of teaspoons of, so I tried some Durham's water putty sprinkled on dry & rubbed in w/ BLO & let it dry. I sanded it & sealed w/ Zinssers sanding sealer & then polyurethane to finish. I did this on oak because I wanted a smooth bar type finish on this piece & it did a beautiful job. (I just posted "Christmas in January" project in the flatwork area)
  1. Light Colored Wood Paneling Question
    By Scott R Smith in forum Finishing School
    Last Post: 01-03-2015, 01:58 AM
  2. Grain filler
    By Leo Voisine in forum Finishing School
    Last Post: 04-06-2010, 03:07 AM
  3. Paste Wood Grain Filler
    By Michael Bischof in forum Finishing School
    Last Post: 12-29-2009, 10:31 PM
  4. BEHLEN Pore-O-Pac Wood Grain Filler
    By Scott Turner in forum Finishing School
    Last Post: 04-17-2008, 06:16 PM
  5. Grain filler
    By Reg Mitchell in forum Finishing School
    Last Post: 07-19-2007, 02:28 AM
