Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Light boxes
    Constantine, MI
    7,887
    Light boxes
    Eight years ago (yes, I do procrastinate sometimes) I headed up the building committee for the expansion of my church's chapel and education wing. We had stained glass windows that were in the front doors, but the doors were shot and we could not find replacements that would fit the glass. So, ever the generous and unthinking man that I am, I volunteered to build light boxes for the windows so they could be mounted on the wall in the lobby.
    This week I decided it was time.
    So, pulling some white oak I had salvaged from some used pews we purchased for the expansion (poetic, right?) I made a quick mitered frame to hold the glass, a diffuser panel, and a melamine back panel onto which I would mount a 20' rope light. The lines (if you can see them in the picture) show the path the rope will follow. I'm hoping the addition of the diffuser panel (cut from a 2x4 fluorescent ceiling lamp panel) will help disguise the individual bulbs. The rope will be mounted using the little clips that came with them attached to the panel with double sided tape. I tried crazy glue, but it would not stick.
    More pictures to follow!
ID:	41079Click image for larger version.
ID:	41080Click image for larger version.
    www.wrworkshop.com
    5,167
    Nicely done. Hard to out do your generosity!
    Is there a reason you did not mount the lights on the Melamine? When I looked at your cross section it seemed there would be plenty of room.
    Just wondering....
    Now you will have to install wall outlets high enough to plug these lovelies into. See, no good deed goes unpunished.
    Constantine, MI
    7,887
    OK. Ditch the double sided tape idea. Not enough holding power to overcome the rope not wanting to follow tight corners.
    Any other ideas before I go out and buy about 100 3/8" machine screws and nuts?
    www.wrworkshop.com
    North West Indiana
    6,097
    Those are going to be beautiful. I think the plan sounds like it should work more than well. Waiting to see them lit up Rennie! (I hope it isn't another 8 years before we see those pictures! )
    Jon
    Constantine, MI
    7,887
    Just wondering....
    The lights will be attached to the melamine, just don't know how yet - see my second post on this. These will mount over a plant shelf that I (cleverly) had several outlets installed in a few years ago. I may be a procrastinator, but I'm a heck of a planner!
    www.wrworkshop.com
    North West Indiana
    6,097
    #6 sheet metal screws? Might look like a porcupine from the back, but that will be agains the wall correct? Just need a spacer so the wall doesn't get scratched up.
    Jon
    Constantine, MI
    7,887
    Quote Originally Posted by Jonathan Shively View Post
    Possibility. I'll be mounting french cleats at the top with an equal depth spacer at the bottom so the box will 'float' away from the wall so clearance should not be a problem.
    www.wrworkshop.com
    North West Indiana
    6,097
    Otherwise, drill holes wherever the clips need to go, haven't seen these things in a while and can't remember their official name, but they usually were made of brass and you used them to hold paper together. They had a round head and like a post from the back, the head was larger than the holes in paper, and then the post was actually two pieces and you bent them down in opposite directions. This might be a safer.
    Jon
    13,427
    Could you use the cable ties that split to wrap around the rope and have a hole on one side for the screw?
    I'll see if I can find a pic, but they are pretty common.
    Constantine, MI
    7,887
    Oooo. That's an idea. I'll give it a look.
    www.wrworkshop.com
  1. Light Box
    Last Post: 08-09-2014, 10:44 PM
  2. Pen Light
    Last Post: 01-23-2014, 02:34 PM
  3. Tea Light
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 03-29-2010, 10:44 AM
  4. Let there be light.
    Last Post: 07-12-2009, 05:02 PM
  5. New Light and Fan Box
    By Jeff Bower in forum New Tools
    Last Post: 05-05-2009, 09:09 PM
