Results 1 to 9 of 9
Thread: Boring a deep hole for hollowing
    Palm Springs, Ca
    1,169
    I made a vessel today and used a long auger bit to bore the center out before hollowing. I noticed that it wobbled and im sure traveled as it bore down to the depth i wanted (see Pic below). I found it really didnt matter and i still was able to hog out just as well. Wondering what others are doing when having to hollow deep. Comments ??
    Honolulu, Hawaii
    1,103
    Dan,
    I'm thinking that the long shank on your drill contributed to the movement of the drill. A shorter drill would help control that better. I use a Forstner bit or a spade bit to drill out hollows.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    30,017
    I also use a Forstner or spade bit for that type of thing. I've got an 8" extension for the Forstner bits, and even with just that much extra length, I get some degree of wobble. Still, nothing that I can't even up once I start turning.
    Goodland, Kansas
    4,834
    I use my hollowing tools. I used to drill but found it was not need. I watched David Ellsworth hollow without drilling and after watching him do it I found I didn't need to. I use Ellsworth tools on smaller pieces and tools made for me by a special friend in southern California for the bigger pieces.
    Bernie W.
    Oct 2009
    Bradford, Vermont
    425
    I just use a long bradpoint bit in a handheld chuck. The torque isn't great enough that it's even really very uncomfortable to hold the chuck. You can get a decent 3/8" to 1/2" bradpoint very easily in 6", 12", and 18" lengths. The shorter the bit, the easier it is to control it.
    -- Tim --
    11,833
    An extension that long is bound to wobble.
    It might help if you put the tool rest on the shank about half way.
    I use this auger I got from Amazon for about 20 bucks, it's a Bosch, don't know if they still have them or not. It's 1.5" x 17". It hogs through endgrain with ease. In fact, I had to dull the threaded pilot point cause it was self feeding to agressively. It will sometimes track off center a bit, but not enough to be a problem. I know a lot of pros don't bother to drill a hole, but my tools are big and crude and homemade, I need the room, and the assist
    Tellico Plains, Tennessee
    4,352
    I have an old style brace and bit type of bit about 3/8" and about 10 or 12 inches long that I've put a handle on so I can just hold it by hand and that's what I use... I don't usually have quite as deep hollow forms as yours though...
    Chuck
    Tellico Plains, TN
    Oct 2007
    Schenectady, NY
    912
    I use Morse taper drill bits mounted directly in the tailstock. No fuss, no muss. Got a whole bunch on eBay a while back for about a dollar a piece. Probably a lifetime supply.
    Don Orr
    Woodturners make the World go ROUND
  1. Hollowing and hole boring question
    Last Post: 12-29-2010, 05:34 AM
  2. Hollowing Deep and wide
    Last Post: 12-15-2010, 12:42 AM
  3. Boring a hole in a stump ????
    By Dan Mosley in forum General Woodworking Q&A
    Last Post: 11-21-2010, 05:55 PM
  4. hollowing deep
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 06-16-2010, 01:22 AM
  5. Deep Boring
    By Tom Storey in forum General Woodturning Q&A
    Last Post: 01-19-2009, 04:14 PM
