Results 1 to 10 of 16
Thread: Cherry Side Table – Limbert Arts and Crafts Style
    Toronto, Ontario, CANADA
    2,332
    (post 1 of 5)
    I built two different items from plans that I found in the September 2009 issue of Wood magazine. One of these was the jewellery/music box that I described in the thread http://familywoodworking.org/forums/...ad.php?t=17385. The other was this side table: Click image for larger version.
Name:	Cherry table 00 -Arts and crafts table from Wood magazine -small.jpg
    The one in the magazine was made out of oak. I made one out of cherry. As usual, I will describe the project by extracting entries from my weekly journal.
    2009, Nov 22:
    This week I started a couple of Christmas projects. The first one is a small table that I am going to make out of cherry. I am going to make the table for Margaret and I am going to use cherry instead of oak. I have a lot of cherry that I bought last year from a guy in Pembrooke. Below is a picture where I am starting to prepare the cherry on my jointer: Click image for larger version.
Name:	Cherry table 01 -Starting to prepare the wood -small.JPG
    In preparing the cherry, I am finding that the wood is not very good. It is hard to get a continuous straight piece and there are twists and punky places that are creating difficulties.
    2009, Nov 29:
    Work continued on the cherry side table:
Name:	Cherry table 02 -Glueing up the top -small.JPG
ID:	41556 Click image for larger version.
Name:	Cherry table 03 -Glueing up a leg-side -small.JPG
ID:	41557 Click image for larger version.
Name:	Cherry table 04 -Sanding a glued together leg-side -small.JPG
    Last edited by Frank Pellow; 01-20-2010 at 10:18 AM. Reason: remove duplicate material
    Cheers, Frank
    2,332
    (post 2 of 5)
    2009, Dec 13:
    On the cherry side table front, I tested various dyes and stains in order to see if I wanted to “improve” upon the colours provided by Mother Nature:
Name:	Cherry table 05 -Testing dye shades -1 -small.JPG
ID:	41568 Click image for larger version.
Name:	Cherry table 06 -Testing dye shades -2 -small.JPG
    In the end, I decided that the dyes and stains revealed too many imperfections in the wood and the finishing of same. As I observed two weeks ago, the cherry I am using is not very good. For instance look at the curve in this glued together piece and also notice the “punky” section of wood: Click image for larger version.
Name:	Cherry table 07 -The Cheery wood is less than ideal -small.JPG
    aside: I admit that this was probably partly due to my inadequate glue-up technique and I know of ways to improve upon this, but you get the point.
    I first trimmed all the pieces to rough size making use of my Incra crosscut sled: Click image for larger version.
Name:	Cherry table 08 -Trimming the pieces to rough size using Incra sled -small.JPG
    then cut the four legs/sides utilizing a jig that I made specifically for the purpose of making cuts that were both 45 degrees and tapered:
Name:	Cherry table 09 -Taper jig 1 -small.JPG
ID:	41572 Click image for larger version.
Name:	Cherry table 10 -Taper jig 2 -small.JPG
    Cheers, Frank
    2,332
    (post 3 of 5)
    2009, Dec 20:
    It was time to get back to the cherry side table. It needs to be completed by Christmas.
    Using the drawings from the magazine certrefold, I created a pattern side/leg from a piece of plywood.
Name:	Cherry table 11 -Preparing a plywood template of one of the four sides-legs -small.JPG
ID:	41577 Click image for larger version.
Name:	Cherry table 13 -Using jig saw on cutout in a side-leg -small.JPG
    Next I used a pattern bit in a hand-held router to make the cut-outs in the four sides/legs. Click image for larger version.
Name:	Cherry table 14 -Pattern-routing a side leg -small.JPG
    I tried smoothing the cuts with my spindle sander, but it is quite aggressive, so I used it sparingly and did not attempt to smooth things completely. Rather, I completed the job using two different profile pads with my linear sander:
Name:	Cherry table 15 -Smooting a side-leg cutout witha spindle sander -small.JPG
ID:	41580 Click image for larger version.
Name:	Cherry table 16 -Completing the sanding with a Festool linear sander -small.JPG
    Next, I rounded over most the edges of the cutout areas:
Name:	Cherry table 17 -Rounding over the cutouts -small.JPG
    Cheers, Frank
    new york city burbs
    10,184
    I had alot of mahogany that had stubborn twists in the wood.
    Instead of gluing up the wider boards(6-8 inches), I cut them all down to 3 inchs or so and got a much straighter top, with less bend or tension.
    2,332
    (post 4 of 5)
    2009, Dec 27:
    I managed to get the cherry table to the stage where it was possible to give it to Margaret on Christmas morning. First of all, there was the sanding, polishing, and waxing the interiors of leg-sides & the shelf parts: Click image for larger version.
Name:	Cherry table 18 -Sanding and polishing the interiors of leg-sides & the shelf parts -small.JPG
    Assembling and gluing the joints between the sides were tricky because of the angles involved and the difficulty of using clamps. I glued up the first joint using a generous amount of long open time white glue with masking tape to protect the interior surfaces from glue squeeze out. Masking tape was also employed to temporarily clamp the joint in some places:
Name:	Cherry table 19 -Leg glu-up -1 -small.JPG
ID:	41584 Click image for larger version.
Name:	Cherry table 20 -Leg glue-up -2 -small.JPG
    I next tried to fit in the shelf but could not get it into place with the cleat in place. So, I had to chisel off the glued-in-place cleat. Click image for larger version.
Name:	Cherry table 21 -I had to remove the cleat in order to fit in the shelf -small.JPG
    Eventually, I managed to glue and clamp all the sides/legs together with the shelf in place. But the plans called for nice sharp edges and mine were anything but sharp (as can be seen in the detail shown to the second photo that follows): Click image for larger version.
Name:	Cherry table 22 -Two legs glued at joint leaving crack at outside of the seam -small.JPG
ID:	41587 Click image for larger version.
Name:	Cherry table 23 -Two legs glued at joint leaving crack at outside of the seam -close up of top p.JPG
    This particular table was obviously destined not to have sharp edges. So, I made a slight modification to the taper jig to accommodate the protruding shelf and proceeded to I bevel all four edges on my table saw: Click image for larger version.
Name:	Cherry table 24 -Bevels were cut along all the leg joints -small.JPG
    Next the table top was shaped, sanded and polished, top, sides and bottom then the bottom side was waxed:
Name:	Cherry table 25 -Sanding and polishing the top -small.JPG
ID:	41590 Click image for larger version.
Name:	Cherry table 26 -Waxing the top -smal;l.JPG
    I used Town Talk Orange Wax which is a combination of beeswax carnauba wax and orange oil.
    The top was attached to the base as shown below:
Name:	Cherry table 27 -Attaching the top to the base -small.JPG
    Cheers, Frank
    How fun. I got a grin out of that piece. Thanks for taking us along for the build.
    2,332
    (post 5 of 5)
    I did not have time to sand, polish and finish the outside of the base before Christmas, so this is what I presented:
Name:	Cherry table 29 -Almost finished -small.JPG
    I managed to finish the table on Boxing Day and here it is in place beside Margaret’s chair:
Name:	Cherry table 30 -Finished and in place in living room -small.JPG
    Cheers, Frank
    2,332
    Thanks Allen, I will give that a try the next time I use the wood on a project.
    Cheers, Frank
    2,332
    Glen, just which piece is it that you grinned about?
    Cheers, Frank
    30,002
    Nicely done, Frank. Thanks for the write-up.
  1. A Little Arts and Crafts
    Last Post: 10-30-2014, 04:20 PM
  2. A Limbert-Style Side Table
    Last Post: 02-21-2013, 08:39 PM
  3. Arts and Crafts Style Floor Lamp
    Last Post: 12-03-2012, 02:45 PM
  4. Arts and Crafts inspired coffee table
    By Russ Massery in forum Flatwork Project Showcase
    Last Post: 10-02-2012, 02:24 AM
  5. Arts and Crafts/Mission Style Entertainment Center
    By scott spencer in forum Flatwork Project Showcase
    Last Post: 08-14-2010, 01:17 AM
