Results 1 to 10 of 13
Thread: Dovetails made easier
    Perth, Australia
    42
    Here are a few strategies for producing tight dovetails. Add your own.
    Marking out with a scale. This makes it easier to adjust the spacing.
    Sawing square is the key to tight fitting dovetails. Ganging up boards makes this easier to do.
    I saw the tails first. The accuracy in sawing these angles is not critical - it is matching these saw cuts to the pins that is critical. Using a dovetail angle marker helps in this regard - not vital, but it does make it easier to replicate angles.
    Dovetail markers also allow one to experiment with different angle ratios. I think that the angle does not make a lot of difference to drawer strength. On the other hand, a wider or narrower dovetail can enhance the aesthetic look. I tend to go for a higher ration (1.5) on thin boards and a lower ratio (1.7 or 1.8) on wide boards.
    Starting a saw cut with the saw raised effectively lowers the rake of the teeth and makes for easier starting. Aim to follow two lines similtaneously (e.g. the angled and the horizontal lines).
    Aim to make your saw cuts as close to the knife line as possible. The tighter your sawing, the less need for paring, and the less chance of errors creeping in. To achieve such close tolerances, use a chisel to chamfer a fence for your saw.
    Before removing any waste, take the time to mark out which areas are to be removed. If you look carefully at the through dovetail end of the drawer above, you will see a cut into the tail! I caught myself just in time. Dang spatial difficulties!
    I prefer to remove waste with a fretsaw/jeweller's saw than chop it out. A recommendation made to me was to add a twist to the blade so that you do not experience the limitation I show here of how deep into a board a standard fretsaw can cut.
    When paring the waste, place the board side-on. This will more easily allow you to see whether you are not holding the chisel over the vertical line . Aim for a slight undercut for a tight fit at the baseline.
    If you find it difficult to judge vertical, then place a square alongside the chisel.
    If you need to chop out waste in hardwood, a guide fence can aid in maintaining even baselines. Note that this is not a vital tool – practice makes one unnecessary. However these are excellent jigs.
    When transferring tails to pins, many use a handplane to rest the tail board. I find that this can easily cause the board to move, which will affect the accuracy of the marking. Accurate marking is all-important for accurate sawing.
    I made a “Rest Block” out of pine scrap onto which I glued 240 grit sandpaper (on two opposite sides – one as a non-slip for the board, and the other as a non-slip for the bench).
    Always transfer marks with a knife. For tight tails you will need a thin bladed knife.
    Prior to joining the boards pare a chamfer on the backs of the tails before wacking them into the pins. This takes two seconds to do and makes the join a smoother process.
    When joining boards, especially when they are hardwood, add a clamp to the pin board to prevent the ends splitting. I close up gaps with a wedge-shaped block.
    Plan the grain direction so that you are able to plane away from the edge of the face board.
    Here is a recent drawer I built. These dovetails all went saw cut to saw cut …
    A close-up of the through dovetails …
    And a close-up of the half blind dovetails …
    Happy dovetailing!
    Regards from Perth
    Derek
    Articles and reviews at www.inthewoodshop.com
    Los Angeles, CA
    2,668
    Thanks Derek. Nice tutorial.
    Jan 2008
    Austin TX
    405
    Derek-
    Thanks for sharing your techniques. You've got some cool ideas; some I've not heard before. Always good to learn something new each day.
    Do you ever accidentially chip off part of the pin, when chiseling the "fence" for the saw to follow? Just curious since there isn't much of a stop-cut at the point where you're removing material. Just the strike of the knife, that marked the pins.
    Regards,
    Lee Laird
    Austin TX
    Central NY State
    3,374
    Good tutorial, as usual Derek. Thanks.
    great job derek!
    Jul 2007
    DSM, IA
    5,719
    Derek thanks for the tutorial!
    My Website
    Derek, great tutorial, thanks for taking the time
    I see you have one of the new Lee Valley saws, how do you like it?
    Bellingham
    2,449
    I just want to echo everyone's comments. You have some really nice tips on making it easier.
    10,604
    Really interesting, Thanks
    Atlanta, GA
    194
    Hi Derek,
    Thanks- that's a nice set of tips. Question- in the 14th photo, it looks like the side is a little wider than the front. Is that on purpose or maybe just a photographic effect (or bad eyesight on my part).
    Charlie
  1. Easier than I thought!
    Last Post: 06-14-2014, 06:54 PM
  2. making life easier
    By Tom Bussey in forum Jigs and Fixtures
    Last Post: 01-04-2014, 04:49 AM
  3. SketchUp Dovetails Made Easy
    Last Post: 02-23-2010, 11:04 AM
  4. is there an easier way to get textures going in the right direction?
    By Mike Gager in forum Designs, Plans and Sketches
    Last Post: 02-18-2009, 08:37 PM
  5. Inlaid dovetails - made a video tutorial, NOT photo tutorial
    By Al Navas in forum General Woodworking Q&A
    Last Post: 10-30-2007, 08:55 AM
