Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: $300.00 - $100.00 toilet
    11,833
    Our house is about 13 years old. It had the old style 5 gal. (or whatever) toilets. One of them started giving problems and instead of repairing, I did what I thought was the right thing. I replaced with a fancy new Jacuzzi Perfecta 1.6 gal. model. Being on a well and septic, I wanted to cut down on water consumption to save running the well and putting unneeded water into the septic field.
    This make and model had been recommended by several people, including my plumber who sells a different brand and could have pushed one of those on me at a considerably higher price. The Jacuzzi has an extra large 'throat' or whatever to allow passage of 'stuff' without plugging. Or it's supposed to.
    Since installing, every few months it stops up. I have a home style auger but that doesn't do the job. So, I call the plumber at $50.00 a trip. It will stop up with an extra large.....uh....'deposit'.
    So far, this $100.00 toilet has cost us, at least, $300.00. I ain't happy.
    I'm going to pop for a professional style auger to do the clearing myself.
    5,323
    Sorry to hear about your problems, Frank. That Jacuzzi model is supposed to be a good one. Maybe your is defective - mold flash, no glaze, or some other problem with the flush channel.
    We've replaced our older toilets with new Kohler 'comfort height' models - at about $250 each - and have been really happy with them. No problems at all.
    Like you, I was concerned with the water use of the old ones, and the potential effect on my septic system. I had also heard some nasty stories about the reliability of the low-flush models, abd was a bit leary about them, but so far my concerns have been unfounded.
    If your $100 toilet has cost you so much in plumber's fees, maybe you should bite the bullet and replace the toilet with whatever the plumber recommends - or use the Kohlers like I did. I do recommend the model we've got, for sure.
    Dec 2008
    Portland, Oregon
    1,898
    I used to have problems with a toilet that kept clogging, I found that this was the easiest way to clear it. A LOT cheaper than a plumber!
    Another thought, could ther be some small obstruction in the pipe that snares debris until it finally clogs?
    Jesus was a Woodworker
    NH
    4,006
    My septic guy say the biggest problem with the low water flush is that there is not enough water to float the stuff to the tank.
    So he recommends every house in town should have one just so he can have a full time cleaning guy.
    Stupid hurts.
    Villa Park, CA
    1,407
    If it's clogging in the toilet itself, I'd recommend a Toto toilet. It's made in Japan and was one of the first low water usage toilets. I have two in my house and no problems at all.
    Mike
    Ancora imparo
    The Heart of Dixie
    4,268
    Yup. If you don't have water drain that is used fairly regular upstream of the toilet the solids can get left behind and lead to a dam and a few of the other kinds of dam too.
    Walked into my basement bath and couldn't figure out why there was tissue all over my bath floor..... then I figure it out!
    This will become one of you most used tools! Solved 99.9% of the clogs.
    Custom built boats and Kits
    The Heart of Dixie
    4,268
    BTW, there is a fairly decent demand for the old style toilets too. Black market toilets. Who would have thought it?
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    I have a low water toilet that would clog. I lifted the toilet and found that the plastic insert in the wax ring had collasped and resticting the hole. I installed a new wax ring with no insert and have had no problems since.
    Villa Park, CA
    1,407
    I'll just comment that here in CA we have low flow everything (toilet, shower, faucets - and the water pressure is low) and the drains work fine. You might look beyond the toilet to see what the problem is (if the clog is not happening in the toilet itself).
    Mike
    Ancora imparo
    Over the years friends, relatives and motels have had low useage toilets that I found lacking. They plugged or didn't get clean flushes. If you have to flush 3 -4 times, the low useage is now using as much as the old type. Most of these were ones that converted when they first started marketing the low useage toilet.
    When I remodeled our main bath last summer, I bought a American Standard low useage toilet ...Champion 4 IIRC......comfort height model. I shopped looking for one with the biggest orfices....on the tank and the bowl. It was more expensive but has performed flawlessly.
    I notice it discharges at the point of desposit as well as around the rim. The two point discharge system and the larger openings seems to have overcome some of the problems I saw when they first came out years ago.
    Ken
  1. toilet recomendations!!
    Last Post: 01-16-2015, 06:31 PM
  2. Toilet Roll Holders ... #2 and #3
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 07-01-2013, 05:43 PM
  3. 3 Year old and the Toilet
    Last Post: 08-07-2010, 12:42 PM
  4. plumbing question, installing a new toilet
    Last Post: 12-17-2007, 02:39 PM
  5. Exploding Toilet (not fun)
    By Travis Johnson in forum Carpentry and Construction
    Last Post: 12-08-2007, 06:05 PM
