Results 1 to 6 of 6
Thread: Arm-A-Seal not drying
    Dec 2008
    Santa Claus, In
    4,779
    Decided to give Arm a Seal a try and I am not liking the outcome. The second coat is still tacky after 12 hours. Shop was warm (60) all night, humidity is low, wood stove takes care of that. This coat just won't flash off. I need to finish this up today. It's for the shop so I was only going 3 coats. Looks like 2 and good. Any hints to speed this up?
    17,475
    you should know the rule that when you need to have something done today it wont be if you can put it aside in a warmer climate it may make it but 60 degrees is on the low side for varnish or poly drying. you can get lacquer to go off in that temp but the others need alittle more time in the cooler climates..
    North West Indiana
    6,101
    Don't be so cheap Steve, open the damper, put a couple more logs on the fire and get that there shop to 90, it'll flash and dry right!!!! I know with the weather we have had that 60 feels downright springlike, but that there finish don't know that!!
    Jon
    Dec 2008
    Santa Claus, In
    4,779
    Jonathan, damper is open and box is full. Now lets see what happens. If you see a mushroom cloud from down south, it's just me
    Dec 2008
    Santa Claus, In
    4,779
    80 for the shop temp did the trick. Little warm, but it worked.
    North West Indiana
    6,101
    We need a smiley face that blows on his knuckles and rubs them across his chest!!!!! Wood heat, don't 'cha love it!!!!
    Jon
  1. Seal coat for lacquer?
    By Darren Wright in forum Finishing School
    Last Post: 08-23-2014, 02:58 PM
  2. Snuffy the Seal
    Last Post: 08-02-2013, 12:33 AM
  3. Garage door seal
    Last Post: 08-18-2012, 01:48 PM
  4. A Navy Seal goes into a bar -
    Last Post: 05-06-2011, 04:47 AM
  5. Deft Laquer / Arm-A-Seal / Seal-A Cell.
    Last Post: 09-24-2007, 01:42 AM
