Results 1 to 8 of 8
Thread: I got all the nuts out of the lathe and new belt in place, but
    Tellico Plains, Tennessee
    4,351
    now I seem to have another problem...
    In an earlier thread I shows the squirrel's or chipmonk's nuts in my lathe that had been sitting idle for about 4 days with the cover open... I've cleaned out all the nuts, put all of the grub screws (set screws --- one of the English turners called them Grub Nuts and it stuck in my head ) back in place (I think), got the belt changed and all put back together... now it seems that I'm getting a slow down or a lug down of the motor when I'm turning a larger piece and put very much pressure on the wood. I can back off and give it a second or two and it goes back to speed. I don't remember having a slow down before I started all this. I could stop the spindle if I got a big catch, but the motor kept spinning and just slipped the belt...
    It sounds like the belt is slipping again, but not the same sound as I got with the old belt...
    Chuck
    Tellico Plains, TN
    new york city burbs
    10,188
    Im with ya chuck,shoot the squirrels.
    Bellingham
    2,449
    What did you expect Chuck? You no longer have the squirrel assist feature.
    Nov 2008
    Ireland
    28
    Hi Chuck,
    I recently replaced the belt on my 1442 and had the same problem. I ran the lathe without a load at each speed for a minute or so increasing the speed until the whole range had been covered up and back down again and it solved the problem for me. An engineer friend, who replaced the belt, told me it would take a while for the belt to seat properly and attain maximum friction on the pulleys. Maybe this could sort your lathe out, hope so. Incidentally, I replaced the belt with a solid belt that had no teeth, like the original, and I think I am getting better drive than before.
    Brendan
    30,008
    Brendan beat me to it. When I had a Reeves drive lathe, I noticed the same thing when I'd install a new belt. I think if you work it a bit, thinks will settle into place.
    17,470
    back awhile when i used to do some mechanicing they had stuff called belt dressing that you would spray on belt to help it get grip...just an idea
    4,351
    Larry,
    I have a can of that in the garage for when the Ford belt gets to squealing... might give that a try...
    Brendan,
    I'll run through the speeds to morrow and see if that helps too... that's a trick I didn't know about.. Thanks.
    Chuck
    Tellico Plains, TN
    11,827
    It takes about three seconds running time for a belt to 'seat' properly.
  1. Replacement variable speed belt for Craftsman wood lathe 351.217150.
    By Wesley Harris in forum General Woodturning Q&A
    Last Post: 08-20-2015, 03:46 AM
  2. drive belt for a wood lathe
    By John Knollmiller in forum General Woodworking Q&A
    Last Post: 10-22-2014, 01:32 AM
  3. Belt sander for sharpening lathe tools?
    By Bill Nicklaus in forum General Woodturning Q&A
    Last Post: 08-09-2012, 11:11 PM
  4. Gun nuts :)
    By Stephen Bellinger in forum Off Topic Discussion
    Last Post: 07-14-2011, 10:02 AM
  5. Could you be as nuts as me?
    Last Post: 02-06-2010, 01:49 PM
