Results 1 to 4 of 4
Thread: Finger joint Box
    Sep 2007
    Bloomington MN USA
    268
    Finger joint Box
    Have made many finger joint boxes in the past, but never one with a sliding lid. Not that it is so dificult as long as yo remember to count # of cuts in the rear of the sides and then cut a couple less in the front of the sides so as to leave room for the top. Also it is much better done on a router table for cutting the 1/8th x 1/8th grooves & rabits. TS works but is a lot more work,as my blade is a thin kurf and requiers 2 passes to get the 1/8th " grooves. Finished with BLO and Amber Shelac and a couple coats of Deft spray & johnsons Past wax.Click image for larger version.
Name:	Finger joint box closed.JPG
Name:	Finger joint sliding lid box 2.JPG
Name:	Finger joint sliding lid box.JPG
    There Must be something I can put in it.6X6x2 3/4" Will hold several DVDs that I use in my shop for Information!
    If you make a mistake it was part of the original plan!
    Indianapolis area
    1,697
    I like it! Thanks for sharing.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    17,474
    looks like you got the count right ron and in the process you triggered and idea for me to use..nice box for the specail somethings
    Dec 2008
    falcon heights, minnesota
    5,610
    better get a move on larry, my bday is about 4 1/2 months from now...
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Shop Notes Variable Finger Joint Jig
    Last Post: 03-29-2015, 04:38 PM
  2. Adjustable Finger Joint Jig
    By Robert Horky in forum Jigs and Fixtures
    Last Post: 09-16-2014, 11:36 PM
  3. A Quick Box For My Finger Joint Blade
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 03-15-2014, 10:04 PM
  4. Box (finger) joint jig for router table
    Last Post: 01-09-2008, 06:18 PM
  5. Finger Joint Jig
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 06-11-2007, 03:05 PM
