Results 1 to 5 of 5
Thread: A Little Heat
    A Little Heat
    I guess I'll put this here, it is not really a new "tool" or such, but it makes Dungeon life a little better.
    I know it does not really get cold here in Tokyo, hey, I'm from the Great White North you know, but it does get a bit chilly. The coldest I've seen it down in the Dungeon is about 10C or 50F yeah, not cold, but if I'm doing something that I'm not moving around, like sharpening chisels, or such, well, I must be getting old or something, but I feel a chill.
    I found a decent "Carbon" heater (something like an infrared heater) on sale here for about $30, it puts out 900 watts of heat
ID:	41694 Click image for larger version.
    I put it up there on some stuff, but it was not pointing to where I stand and sharpen stuff, so I had to do something different with it, I remembered seeing one that Lee Valley offered........
    ....... and I had an idea.....
    ...... I had to modify it, take out the "Tip Over" switch, remove the base and such, but all in all, this is an nice addition to the Dungeon. I will certainly not heat the whole place, but I don't need that, kind of task heating, like a task light.
    Heck, soon I'll be turning on the AC, as winter will be over
    12,256
    Nice one Stu. I agree with you. Sometimes 10C feels colder than -15C to me. Dont know what it is, probably got to do with what we wear when we know it aint really freezing versus what we wear when we know we wont survive if it is.
    Good deal for $30.
    Just one thought that came to my mind not being able to see the elements.
    In the original config the heat would have risen vertically off the elements. Withe elements now mounted horizontally the lower one will be heating the upper one. Are they capable of taking that mutual heat. You mentioned "carbon" element which i dont know hence my thought provoking question just for safety sake. Would not want you having something go wrong there. Sure looks fine based on the LV config.
    Cheers
    Cheers
    I think it will be just fine, they had a very similar heater, with three elements but horizontal like, made by the same company, using the same elements, just a bit shorter, I have two, so each is 450w, the horizontal one has three, each 300w.
    The carbon element looks like a fairly thick string, coiled up inside a glass tube, the string looks burnt, and glows red when the power is turned on
    Seems to work
    LLooks like it'll get the job done. Not to hijack your thread but yesterday must have been the day for heater. I went to the orange borg and picked up this little unit. Click image for larger version.
ID:	41723 1500 watts max. occilating or stationary. I wanted one with a fan built in, i had several of the radiant type in the past and didn't feel they got the job done. $29.95.
    10,604
    Man Stu, you must have a mini nuke plant down there.
    You must use more power than then Las Vegas
  1. Heat is ON
    Last Post: 10-03-2011, 06:16 PM
  2. Got heat and got work
    Last Post: 12-17-2010, 12:15 PM
  3. Got heat
    Last Post: 12-06-2010, 03:23 PM
  4. I need HEAT
    By Paul Gallian in forum Off Topic Discussion
    Last Post: 01-03-2010, 02:37 PM
  5. Handling the Heat
    Last Post: 07-27-2007, 06:55 PM
