Results 1 to 10 of 28
Thread: Wavy Ash NE Bowl in Progress
    30,008
    I usually don't show a lot of progress pics here, but the piece I turned last night was kinda interesting, so I figured I'd share it. Pardon the overabundance of photos.
    I started out with a piece of dried ash from recent 'Going Out Of Business' giveaway at a local firewood lot. This chunk had a wavy outer surface, which looked promising for a natural edge bowl. The dimensions on the bark face were about 24" by 18". I started with a beater chisel to make a flat spot for the faceplate...
Name:	Scalloped Ash NE Bowl Progress 01 - 800.jpg
    Then I used long hex head sheet metal screws to hold it. I don't drill pilot holes. I just drive the screws in with an impact driver.
Name:	Scalloped Ash NE Bowl Progress 02 - 800.jpg
    Here's the initial blank mounted on the lathe. It's blanks like this that make me glad I got the dropped bed extension for my 3520B.
Name:	Scalloped Ash NE Bowl Progress 03 - 800.jpg
    Here's another view. Notice that the spindle indexing pin is in place. The piece was pretty badly out of balance, so needed to use the electric chainsaw to trim it up a bit on the lathe. I use the indexing pin to hold things in place while I'm cutting. Also note the lathe is not even powered up. That's just a reminder to not hit the switch with the spindle locked.
Name:	Scalloped Ash NE Bowl Progress 04 - 800.jpg
    And here's the blank after a bit of chainsaw balancing...
Name:	Scalloped Ash NE Bowl Progress 05 - 800.jpg
    Tool rest and extension in place...now the fun can begin.
Name:	Scalloped Ash NE Bowl Progress 06 - 800.jpg
    Do you really want to stick a piece of sharp steel into that?
Name:	Scalloped Ash NE Bowl Progress 07 - 800.jpg
    Making a little headway. The ash is dry and hard, so progress is slower than on a piece of green wood. It's also still pretty unbalanced, so I was running in the 250 to 325 RPM range at this stage.
Name:	Scalloped Ash NE Bowl Progress 08 - 800.jpg
    A while later, it was down to this shape, about 17 1/2" across.
Name:	Scalloped Ash NE Bowl Progress 09 - 800.jpg
    And a look from the headstock side...
Name:	Scalloped Ash NE Bowl Progress 10 - 800.jpg
    More in the next post...
    30,008
    continued...
    After reversing the blank, I did the final cleanup on the outside of the bowl. The next step was to hollow the inside out. Doesn't this look like it's gonna be fun?
Name:	Scalloped Ash NE Bowl Progress 11 - 800.jpg
    Making some progress, but it's slow going. I was using my Monster Indexer (Oland-style tool bit holder on a heavy handle) for the bark removal stages. You can also see that I've slid the headstock back and am now turning over the regular bed, not the dropped extension. This reduces the slight vibration that's introduced by using the tool rest extension. Even though it's heavy steel and iron, the extended tool rest vibrates more than the regular one.
Name:	Scalloped Ash NE Bowl Progress 12 - 800.jpg
    Getting there, but the bottom is still about 4" thick, and the walls are still too thick as well.
Name:	Scalloped Ash NE Bowl Progress 13 - 800.jpg
    Finally to the finished dimensions. I was fighting some tearout, so I used a spray bottle and some water to help make the cuts a bit cleaner. (You can see the wetter spots in the picture.) I still had a fair about of 80 grit work to do on the tips along the rim. I'd rather spend extra time sanding than risk blowing a piece up trying to take the proverbial just one more cut.
Name:	Scalloped Ash NE Bowl Progress 14 - 800.jpg
    And here's how it looked at the end of the evening. I still have more sanding to do, plus a bit of reconstructive surgery on a couple spots of bark, but this is pretty much how it's gonna look when finished. It's 17 1/2" wide and about 8" tall at the highest points.
Name:	Scalloped Ash NE Bowl Progress 15 - 800.jpg
    I should be showing finished pics in a week or so...
    Comments, finger-pointing and name-calling are welcome.
    NH
    4,005
    That's one cool bowl
    As for name calling............*points finger at Vaughn* You window licker
    Stupid hurts.
    Goodland, Kansas
    4,834
    Vaughn that is one fine looking bowl. Really well done.
    Bernie W.
    Reminds me of a fancy cut Giant radish --
    Very nice !!!
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    4,552
    Man that looks like fun Vaughn
    Palm Springs, Ca
    1,167
    ...........WOW.................enough said..........i really like that and with a finish it will be fantastic
    That is one heck of a BOWL. Nice work.
    Dennis
    Buse Township MN
    565
    I really, really, really like this one!! Can't wait to see that finished.
    Why didn't you trim the blank to 18 x 18 to start though??
    Every child deserves a family. Adopt. Foster. Get involved.
    Super piece of wood, and a super job at freeing that nice NE bowl that was in there
  1. Another Wavy NE Ash Bowl
    Last Post: 04-15-2010, 01:29 AM
  2. in progress natural edge bowl
    Last Post: 03-05-2010, 12:12 AM
  3. Wavy Edge Ash Bowl
    Last Post: 02-07-2010, 08:46 PM
  4. Curly Maple Bowl - In Progress
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 03-10-2009, 12:41 AM
  5. Second Bowl in progress
    By Keith Palmer in forum Lathe Project Showcase
    Last Post: 09-27-2008, 03:17 AM
