Results 1 to 10 of 14
Thread: Tapering jig
    Livermore CA (SF Bay Area)
    51
    Tapering jig
    I am interested in building a jig to make tapered legs on my table saw. I would be interested in anything you have built that will safely accomplish that task.
    Thanks to all!
    Warren
    Constantine, MI
    6,972
    I built the one from Norm's plans - simple and works like a charm.
    8,435
    I was going to make one but I picked this one up a Rockler. It was on 15 bucks and it works as advertised.
    688
    Hey Warren,
    Here's my tapering jig. There was an article in the other FWW (the magazine) a couple years ago that showed how. The basics are a platform with a slider on the bottom that fits into your miter slot, a fence/stop at the rear to hold the leg, and another fence at the taper angle. You also need some way to clamp the workpiece to the two fences. If this is a one shot need, I would just glue/screw everything together at the desired angle and screw on one of those lever clamps.
    The good thing about this jig is that your fingers are far away from the action
    PM me if you are interested and have questions.
    17,230
    hey jesse was you takin nap when you attached that pic its 90 degrees off
    another idea would be to have the bottom staionary and the top move to the desired angle i saw it in a popular wood working mag dont have a pic it kinda worked like a zero cleance insert thtought pater you setup the parent peice to be cut off as it went along the fence then you could use that edge as aguid fo rthe desired angle. with a clamp sytem the parent piece was 1/2 ply witha solid backer piece and then pivoting side piece.
    Wake Forest, NC
    292
    I did the same thing as Don, was going to make one, and got almost the same one for $5.
    FWIW, I have started using the jointer to do them more than the tablesaw. If I were going to make a jig, Jesse's is the way to go.
    51
    Thank you all!
    I really appreciate the suggestions. I have one of the Rockler jigs and have been 'feared to use it. Just doesn't seem to instill confidence, but it might just be me.
    I think I will go with a modification of FWW's jig.
    Thanks again!
    Warren
    4,992
    warren, whenever i`ve needed to taper on the tablesaw i`ve just used a sacrificial piece of mdf with stops shot to it and a couple of clamps.....throw away when done.....tod
    17,230
    latest issue
    in the feb issue of woodworkers joural it has a tapering jig like i tried to describe. page 73 i think.
    The Heart of Dixie
    4,265
    I have always intended to build a jig similar to the Rockler's shown but just never have. Last ones I cut I freehanded on the bandsaw and then hand planed to the line.
    I had to make repeat cuts for some taper columns so I made a simple sled like Tod spoke of. I had to make a Right and Left handed one. I just used some Luann I had and laid it out on there. Then just added some stop blocks to hold the blanks in place.
    Custom built boats and Kits
  1. Tapering shoulders of a mortise and tennon.
    Last Post: 01-04-2012, 12:09 AM
  2. Tapering round stock
    By Peter Rideout in forum General Woodworking Q&A
    Last Post: 11-25-2008, 01:26 PM
