Results 1 to 3 of 3
Thread: TS3650 question
    Mar 2009
    Glencoe, Minnesota
    4
    TS3650 question
    I' am thinking of changing my TS3650 table saw belt to a Power Twist link belt and I was wondering what size I would need 3/8, 1/2?
    Thanks!
    Dave
    17,471
    i am not familiar with your saw but you just match the width of what you have with the twist link one..1/2 gets a 1/2 and so on..
    30,014
    I have a TS3650, and unless you also change the pulleys, I don't think a link belt is gonna work. The factory belt is a flat ribbed belt, and the pulleys are machined specifically for that kind of belt, not for a typical V-shaped belt (which is essentially what the link belts are). And even if you could use a link belt, I don't think it'd be any improvement over the factory belt. The flat ribbed belt would be considered an upgrade on a contractor-style saw that uses standard V-belts. (I use link belts on my jointer and drill press, so I'm familiar with them and the improvement they can provide.)
    Is there a problem you're trying to solve by changing the belt? Maybe there's another way to handle it.
  1. TS3650, End of April, SW Vermont
    By Tony Maio in forum Classified Ads
    Last Post: 02-15-2013, 10:55 AM
  2. TS3650 - 6" or 8" Stacked Dado Set?
    By David Agnew in forum New Tools
    Last Post: 02-13-2013, 10:28 PM
