Results 1 to 7 of 7
Thread: Things are shrinking over here
    Cornwall, England
    392
    Talking Things are shrinking over here
    I was asked to make some things for someone who collects dolls hsouses. These are 1/2th scale so equate to being a 12" bowl and a 9" tall vase. Made of beech. The coin is a 5p piece, not sure of the equivalent size coin in foreign money
    Pete
    Goodland, Kansas
    4,834
    Very well done Pete. Really nice small turnings.
    Bernie W.
    Oct 2009
    Bradford, Vermont
    425
    It's good to see somebody ELSE making a few li'l bitty turned pieces for once!
    Here's a few minis I've done:
    Phillipine ebody, tagua finial:
    Tagua bowl:
    Fiddleback maple plate & bowl (that's not tearout on the plate):
    -- Tim --
    Sep 2008
    Redford, Michigan
    53
    I'm pretty sure a 5p piece is foreign money. Nice work on the nearly invisible bowl and vase though
    Central Illinois
    936
    Great Job there. It's hard to do details on mineatures.
    Our doll houses, this side of the pond, are not as grand, they are 1/12 scale.
    If I remember correctly, your 5p is about the size of our nickle (5 cents).
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    29,443
    I'll bet you guys had to add a lot of ballast to your lathes to be able to swing those monsters without having your lathes go walking across the shop. The sanding must have been a killer, too.
    Great work, both of you.
    Cornwall, England
    392
    Not as bad as these little pests. I was asked to make these for someone.
    Mahogany, 15mm
    Walnut 15mm
    Walnut 24mm
    Walnut 30mm
    Let's just say I won't be cutting my finger nails for a while.
    Pete
  1. Doing the Things that You Already Know You Should Do.
    Last Post: 03-25-2016, 05:09 PM
  2. It's the little things...
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 07-02-2012, 05:12 AM
  3. A lot of things
    By Massimo secco in forum General Woodturning Q&A
    Last Post: 12-27-2010, 02:39 PM
  4. Little things
    By Pete MoncrieffJury in forum Lathe Project Showcase
    Last Post: 02-19-2009, 05:13 PM
  5. Three things
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 09-14-2008, 05:08 PM
