Results 1 to 8 of 8
Thread: Draw leaf table
    Thorn, Netherlands
    4
    Draw leaf table
    Does anyone have plans for a draw leaf table?
    Thorn, Netherlands
    4
    I decided to draw the plan myself in Sketchup. The final file is too large to upload here, so I placed in in the 3d warehouse. Comment please?
    I took the liberty of saving your file as a jpg to post here so other can see it easier.
    I like the looks of your table but am wondering how the extension bar will work. It apears from your drawing that they simpply ramp up as you pull the leaf out. Most drop leaf tables I've seen you pull the leaf out pst the point of opening then lift the leaf and push it back in.
    Thorn, Netherlands
    4
    I will try to explain how it shout work. But I am Dutch so English is not my first language.
    The top blade is lieing loose on the table. So when you pull out the side blades, the to blade is lifted up. When the center blades are in there outer position, the top blade falls back in its position. To put the side blades back in you have to lift the top blade a bit and push the side blades. I hope this clares the design a little bit.
    That was a perfect answer to my question. Welcome to the forum and please post pictures of the build as your doing it.
    SE Minnesota
    2,526
    http://blip.tv/file/3185423
    A smaller SKP file of the table. I hope Wout doesn't mind.
    Thorn, Netherlands
    4
    Quote Originally Posted by Dave Richards View Post
    I don't mind. And the little clip is also nice. But can you explain how you made the file smaller?
    SE Minnesota
    2,526
    The image for the oak material you used on the table top is 1.98Mb. It is much larger than it needs to be. I reduced that image to 138Kb and reapplied it to the table. There's no need to use high resolution images for materials in SketchUp since you won't see the benefit.
  1. Colonial Drop Leaf Tavern Table
    Last Post: 12-17-2013, 02:35 PM
  2. Table that needs a leaf
    By Dave Hawksford in forum Flatwork Project Showcase
    Last Post: 05-14-2009, 02:49 PM
  3. Who Needs a Computer to Draw Furniture?
    Last Post: 07-11-2008, 12:35 PM
  4. How to draw an arch in SU?
    By Charlie Schultz in forum Designs, Plans and Sketches
    Last Post: 06-04-2007, 05:19 PM
  5. SKETCHUP Draw Leaf Table
    Last Post: 05-08-2007, 01:37 PM
