Results 1 to 8 of 8
Thread: Crosscut Sled Size
    Dec 2008
    Santa Claus, In
    4,779
    Crosscut Sled Size
    I am going to build a sled or two. What are the size(s) that you have? I think I want one with a double runner and a single runner for small pieces.
    My regular cross cut sled is 40"x20". MY Dado sled is 24"x18"
    "Thereís a lot of work being done today that doesnít have any soul in it. The technique may be the utmost perfection, yet it is lifeless. It doesnít have a soul. I hope my furniture has a soul to it." - Sam Maloof
    17,470
    my double runner is 38 wide and 28 deep. ..don, i would like to see your dado sled????
    It ain't nothin fancy just a double runner with a 3/4" slot.
    I wish I'd made it bigger but it gets the job done.
    3,134
    Panel sled 33' deep x 4' wide cuts lower cabinet sides nice & square.
    12,247
    Steve I aint finished mine but after great help from folks here i will be putting an insert in the middle so you can do either dados or cross cuts and tilted blade inserts too.
    Villa Park, CA
    1,407
    Make it at least 24" deep. You'll be surprised at how often you need to cut a panel two feet wide. There's a limit to how deep you can make it, of course. Eventually, it could cover the whole saw and when you pull it back to get that wide panel, it falls off the saw.
    Mike
    Ancora imparo
    I'm sure all of mine have appeared in one sled thread or another. Mine have ZCI's so I have sets of throats for blade or dados. Same sled different throats. My small bevel sled is about 2" square with tracks for holding box sides and other small parts for mitering along the edge. My "small" sled is used for most things; 36" wide with 20-1/2" between the fences. The blade path is about 12-1/2" from the right side giving me more support at the left. Your shop layout may not benefit from this.
    The "large" sled is again 36" wide but about 38" between the fences. Again the blade path is about a third of the width from the right. I also have a frame-type miter attachment for the large sled that is fixed for 45*. The reason for multiple sleds is ease of setup. Except for dados, I just grab a sled and use it; no setup. There are of course, times when the last thing I did was a dado and I have to change the throat for a blade.
  1. New 'smaller' Crosscut Sled
    By Ned Bulken in forum Jigs and Fixtures
    Last Post: 01-01-2013, 02:40 PM
  2. Elementary Crosscut Sled Question
    By Cynthia White in forum Jigs and Fixtures
    Last Post: 01-22-2011, 08:46 PM
  3. Crosscut sled
    Last Post: 11-22-2010, 07:36 PM
  4. Crosscut sled completed!!
    By Craig Johnson in forum Jigs and Fixtures
    Last Post: 02-22-2009, 04:13 PM
  5. Big Ol' Crosscut Sled
    By Vaughn McMillan in forum Jigs and Fixtures
    Last Post: 06-06-2007, 01:04 AM
