I have a kitchen remodel
(At this I assume you are general contracting the remodel)that I am in the middle of. The maple cabinets are installed and they are sanded and (were) ready for finishing, but they are yet raw wood.
Today, the countertop installers installed the full height backsplash.
( everyday we hear of jobs held up for one reason or another, the sequence needs be followed, the job should have been stopped before the installers started)The bottom of the upper cabinets meet the backsplash at six places. The installers caulked the gaps between the backsplash and the wall, including the joint between the backsplash and the cabinets in those six places. At five of those junctions, they wiped/smeared
(I hate those words and the people who do it cause they just don't care.) the clear caulk on the raw wood maple plywood. The spots range in size from 3/4" x 1" to 1" x 1 1/2".
I believe/assume the caulk is a latex product but I don't really know exactly.
(Contact the installer) important, rise above the anger to solve the problem!
How can I remove the caulk and will I be able to remove it completely so that it doesn't affect the finish?
Get some maple plywood scraps and "smear" some on the edges in slightly larger areas, leave some unsmeared areas adjacent to that on the same board to test with the several possible finishes.Your finish may blend with the smear,hopefully,or while the smear is damp with the finish use your scraper. Do another smear on another piece of ply to try solvents, and denote each one so you remember what solvemt did what. To my knowledge most caulking is a surface, not penatrating substance, You may be best off with the scrape and sand, but be careful with that veneer. Sadly, you will have more luck solving this problem than you will getting the installers to care . But you know what...We Care!!!
I will need to back charge the installers for the needed repairs (to this issue and for the dings that the guy who did the template put in the faceframes).
( you are angry and you have that right because you care about the job, try wetting the dings and cover with a wet cloth and hot iron over them exercising caution as you go. It may help the dings. When finished with the wet areas wipe the entire board with water, just to make it all damp, sand when dry.) Any idea on a charge for this repair to these five areas?
Thanks very much for your help, suggestions and advice.
