Results 1 to 8 of 8
Thread: Finishing Turn Table
    Palm Springs, Ca
    1,169
    I bought a small lazy susan hardware bracket today at Lowes for $4 something and cut a couple scrap pc's of plywood to make a small finishing table.
    Total Cost - less than $12.00 im guessing
    Total Time - less than 15min
    Im thinking ill put a hole in the middle with fat dowel sticking up so when i turn vessels i can finish the entire thing or if its a bowel the entire outside at once. Once dry the inside can just sit on the ply and inside sprayed for wiped easily..............thoughts?
    Attached Thumbnails Attached Thumbnails finish table-1.jpg   finish table-2.jpg
    Jul 2007
    DSM, IA
    5,719
    I like it Dan, I have the lazy susan somewhere in the garage and have the same thoughts of how to use it.
    My Website
    3,132
    I agree good idea been thinking about the same thing.
    Looks real handy, Dan. I use something similar with rounded-off nail tips sticking out of it. I can finish both sides of a piece and set it on the nails to dry. I can also put a round piece of melamine-covered particle board on top of the nails when I need a flat surface. I've also got a dowel stuck vertically into a piece of scrap wood that I can use to suspend hollow forms and narrow vessels upside down. One of these days I intend to make a modular turntable system that can accept various "holders" to the turntable base.
    Palm Springs, Ca
    1,169
    Thanks.....thinking a couple of holes in the middle for a couple different size dowels....with the large dowel i can put a small flat round pc of ply on it when i need to for bowls or leave it off for vessels.....and a smaller dowel hole for other small vessels....the dowels would be long so the projects sits up for easier spraying..........
    Dec 2008
    Portland, Oregon
    1,898
    If you put a piece of peg board on the top you can use sharpened dowels in the holes to support the work piece. gives you more places to hold up the work piece.
    Jesus was a Woodworker
    I made one a while back, and yeah, it is really handy for spraying that rattle can finish. I too use the rounded off nails for holding bowls etc, works great!
    One day I'm going to make one with a very slow speed motor attached
    Goodland, Kansas
    4,834
    I made 2 of them a couple of years ago. A smaller and larger one. Both are really handy especially spraying rattle can lacquer or poly.
    Bernie W.
  1. Finishing Teak Table with Tung Oil
    By Kate Somerville in forum Finishing School
    Last Post: 12-20-2014, 05:17 PM
  2. Replies: 24
    Last Post: 07-04-2014, 02:04 AM
  3. Quick question about finishing a table top
    By Roger Tulk in forum Finishing School
    Last Post: 12-08-2013, 02:17 PM
  4. Finishing table top after painting
    By Dan Pierce in forum Finishing School
    Last Post: 02-13-2010, 03:17 PM
  5. Large Burl Table Finishing Question
    By Dan Mosley in forum Finishing School
    Last Post: 12-28-2009, 01:53 PM
