Frank Pellow
- Toronto, Ontario, CANADA
Feb 3rd Update (part 2 of 2)
04) There is a double layer of ¾ inch MDF on the top with a rectangle cut out of the middle of the top one of these.
I wanted to preserve the cutout so had to be quite careful making the cut. I did this by first drilling a couple of small holes right on the line near a corner then using a very small jigsaw blade to make a plunge cut. Here is the first such cut:
05) I have a profiler attachment for my Festool linear sander that makes it very easy to sand the dowels (which were recycled from a previous life):
06) I attached a layer of ¼ inch hardboard on top of the MDF. The idea is that this can be replaced in the future when it gets beat up. The plans suggested that I do this using double sided tape. I did try this:
but, it did not work very well; I subsequently screwed down the hardboard from the top surface with slightly countersunk screws.
07) Here is the cart with the insert that will be used when the cart is being stored and when it is being used as an assemble table, etc.
08) Here is the cart with the spindle sander insert:
09) Here is the cart with the partly completed router table insert:
The wood on top of the router cabinet is just there to give me a feel of the location of the table top and the fence.
