Curbside Chair Repair - Work's Done
Monday afternoon, I noticed a broken chair left on the curbside a couple blocks from my house. I saw it again late Monday night on my way home from my Pool League match, but this time I stopped and had a closer look. It looked repairable, so I ended up bringing it home before it got soaked in the Tuesday storm and ruined.
The chair really wasn't in too bad of shape. The left arm had been broken off, but it was a clean break. The finish was OK, and the seat cushion was in good shape. (It's not shown in any of these pics.)
The front of the arm broke near a steel pin that attached it to the top of the leg. The pieces fit together well, so this would be an easy fix with PVA glue. (I had Elmer's Wood Glue handy.)
The back of the arm broke at the joint between the arm and the main stile. The break was clean, but the two 1/4" dowels had broken and frayed, so they were not going to glue up as they were. I don't have a pic of the broken dowels, but here's how the two sides of the joint looked after I cut and sanded the dowels flush:
I briefly considered drilling out the two dowels and replacing them, but because of the way the front of the arm was broken and the angled approach I needed to use to fit that joint together, I wouldn't be able to put the pieces together with one or two dowels sticking out of either the arm or the main stile. (Well, I could have, but I didn't feel like breaking any additional joints apart to do it.) Instead, I decided to drill from the back, insert a single, bigger dowel, and plug the resulting hole. (I wanted a face grain plug instead of the end grain of the dowel.) The front of each arm already had a plug in it to hide the steel pin, so plugs weren't unprecedented on this chair anyway. Here's an out of focus shot of one of the existing plugs. You can see it's not exactly well-hidden:
Using a high tech and microscopically measured depth stop on my drill, I drilled the hole for the dowel. For symmetry, I also planned to put a plug on the back of the other main stile too. (But no dowel. I figured it already had two in it anyway.) I turned a short dowel and used a plug cutter to make a couple of face grain cherry plugs. I turned the dowel to be a bit looser than normal to ensure I would be able to drive it to full depth. I'm going to dye the plugs when I fix up the finish, and I figured I could get the cherry to match the existing stain pretty easily. Turns out, the chair's most likely maple, but I should still be able to get the plugs dyed to match. The wood was tough drilling, whatever it is, even with a brand-new brad point bit.
After a dry-run on the clamping, I stuck it all together. I used PVA glue on the front of the arm since it was a good side grain to side grain joint, but used epoxy on the back to fill any potential gaps in that joint or around the dowel.
Here's the chair in the clamps:
The front of the arm:
The back of the arm:
A shot of the left-hand plug:
And the matching (fake) one on the other side:
Wednesday evening I'll play around with dyes, and see if I can take care of hiding the plugs. While I've got the dye out, I'll also touch up any other scratches and scrapes, as well as disguise the front joint a bit better. Then I'll touch up the shellac where necessary, including fixing one or two runs I've found in the existing finish. I'll post more pics when it's all done.
I'm not sure what I'm going to do with the chair when i finish it. Even though our house us decorated in a style that leans heavily on the late 20th Century Hand-Me-Down school, this chair doesn't really fit our present 'decor', if you want to call it that. ('scuse me for a second while I stop laughing.) I have no idea what a chair like this is worth if I were to try to sell it. Anybody here know? What style it this? Is it potentially valuable, or just an old chair? Despite the fact that it broke, it's well made using good wood. It has no visible screws, and uses old-school joinery and finishes. Not Ikea stuff, for sure. I'm seriously considering just taking it back to the original owner's house and just leaving it on the front porch or in the driveway. Maybe with a business card, or maybe anonymously. :rolleyes: ;) (I like to mess with people's heads...in a good way.) :D
Great fix, and you know what I'd do, I'd wrap it up with a bow and put it back at their house with a note, something clever, "You know who" or "The Busted Chair Repair Fairy" or something like that.
If you put your business card, they might think that you are wanting to get paid..... then again, you could always tell them you enjoyed fixing it and if they need anything more fixed, or know anyone that would be great, cheap advertising.
You're thinking along the same lines as me, Stu. A ribbon and bow, for sure. :thumb: As much as I like the idea of being The Midnight Woodworking Ninja (which sounds much better than The Busted Chair Repair Fairy :rofl:), the word of mouth advertising could be worth much more than the chair. If I did leave a card, I'd be sure to stress that the repair was for my own fun and practice, not money. (And of course mention that I'd be available for paid work if they knew anyone who needed similar problems solved.) ;) And the chair's owners would still get the surprise of the thrown-away chair coming back to them fixed...for free. :D
Nice repair! The only thing I'd have done differently would've been to inset the dowel a bit deeper, and make a face grain plug to better match the finishing.
I've done a couple similar repairs, using a cut off 5/16" bolt instead of a dowel, epoxied in and covered with a plug. Very strong, and virtually unnoticeable if the finish match is good.
Vaughn, I like The Midnight Woodworking Ninja! :thumb: We furnished our home this way for quite awhile, until the hand-me-downs came rolling in. We still have quite a few pieces that we salvaged from dumpsters, curbs and alleys.
At one time there was a show on that had 2 brothers that took stuff from the curb, made it into something different and then put it on the porch and rang the doorbell. Not sure if it's still on (don't have cable anymore) but some of the stuff they came up with was kinda cool.
BTW nice fix too. :D
Even more hilarious would be to see it back out in the trash the next day!!! :) :) (Occasionally things get accidentally broken....like the leg lamp in Christmas Story)
I like the idea of giving it back, also.
Regarding the dowel in the back of the chair, remember that Sam Maloof used to comment that a screw was just a metal dowel.
Mike
From a woman's perspective: if I threw it out, my mind is already on its replacement. Don't want my trash coming back to me!
Might check with your LOML before you act. Might be better to "shop" it around the antique stores, if you want to do this kind of work. They may be better impressed and you may get some work there.
Just sayin'...
Vaughn, nice repair job for sure. My wife still uses a cheapo windsor I found in someone's trash and fixed.
As for the ninja repairman, it is a great and funny idea. Perhaps in your note you could add that if they don't want it, you'll take it back, that way any desire on their part to be rid of it won't be a problem. As for style, it reminds me of some places I've been that had plastic slipcovers on the sofa.....
Very cool all in all.
Whatever you do with it, the idea of soliciting furniture repair business may be excellent. In down times folks tend to make do rather than replace stuff. And/or you could scavenge Goodwill and Salvation Army stores for broken furniture, fix and resell at a profit.
But, nice fix.
BTW, I believe it is a fairly new chair, not antique repro or anything special.
Thanks for the comments guys. :)
..The only thing I'd have done differently would've been to inset the dowel a bit deeper, and make a face grain plug to better match the finishing...
Jim, I'm guessing you missed the part where I said I inset the dowel and covered it with a face grain plug. :p I should be able to dye the cherry to match the brown stained maple pretty well.
...Perhaps in your note you could add that if they don't want it, you'll take it back, that way any desire on their part to be rid of it won't be a problem...
That's a brilliant idea. Like others have mentioned, I figured there's a chance they don't want it anymore. The offer to take it back if they don't want it gives them an easy out. :thumb:
Hey Vaugh all of the post is a neat idea. We have a Canadian show here that is called "Junk Brothers". It stars two guys who go round pick up somebodys old junk and then take it back their shop and convert it to somthing else. Then when revamped they drop it off at the peoples home usually leaving it in the driveway and ring the bell and run and sit filming the reaction from their truck. They have a little metal laser cut logo badge that they screw on each piece to let the people know where it came from and I think the whole thing is a little staged cause they end up in the peoples home showing the item in its new place.
http://www.hgtv.ca/junkbrothers/
You could be the SoCal Junk brother.:D
I think the metal dowel you refer to was perhaps a nail?:rofl:
Great idea to return it to them as everyone said. Keep us posted now that you have us intrigued by the possible reaction.:thumb:
Good repair by the way.;)
Carol, forgot to mention I like your suggestion of taking it to a few antique shops to show some of what I can do. Even if I do give it back to the original owners, I could use it to do a bit of advertising beforehand. ;)
I don't know, I think if it were me I'd break the other arm and throw it out in your trash. Since my wife would probably see it and start throwing out all the other stuff in the house, starting with my stuff...of course. Then she'd start decorating the entire house around that darned chair. :rofl::rofl::rofl::rofl:
