Results 1 to 3 of 3
Thread: Refinish of a vessel
    Palm Springs, Ca
    1,169
    buffed out a vessel last night and saw alot of marks in the finish which I didnt notice before. The vessel was finished with 3 coats of Danish oil and a couple coats of varnish. I think im going to wipe it down with MS, let dry and with 0000 rub it down good. then start the buffing over again.
    Anyother ideas ?
    Thanks Dan
    Goodland, Kansas
    4,834
    Was the finish kind of sticky Dan? I generally let the oil finish dry for a while maybe 3 weeks before I top it with anything if I do put something on top. I found if you don't and the oil is not cured your will get streaks or marks in it. Just been my experience. I generally don't put a finish over any oil finish that already has varnish in it except for straight tung oil or BLO. IMHO just don't think it is needed. I let it cure for 3 weeks or so and then buff the oil finish.
    Bernie W.
    Palm Springs, Ca
    1,169
    Bernie----you may be right, I only let it sit for a couple weeks and then put the varnish on because i didnt think the grain was filled well enough with just the 3 coats of varnish. I should have just used grain filler or 50/50 laquer and laquer thinner as filler.
    I steel wooled it down tonight and will probably put a satin laquer finish on it - probably several coats - let sit for 3 weeks as a precaution (cold out here right now and im sure will take a bit longer to cure anyway)....then buff or if the coats look good may just leave it........
    I have a good amount of mesquite but unless i fill the grain the finish just does not come out looking all that great. So far the best way i have found to finish it is to use the 50/50 mixture and then a few top coats of satin-semi or gloss depending.
  1. New refinish project
    By Jim Burr in forum Finishing School
    Last Post: 01-12-2014, 08:00 PM
  2. Deck Refinish
    Last Post: 05-05-2012, 09:55 PM
  3. Table and Chair Refinish
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 07-18-2011, 02:19 AM
  4. A refinish project - table top
    By Rick Prosser in forum General Woodworking Q&A
    Last Post: 06-12-2011, 04:12 AM
  5. refinish table
    By ken lutes in forum Finishing School
    Last Post: 12-30-2009, 06:06 PM
