Results 1 to 10 of 21
Thread: Palm Routers, here's what I brought home!
    North West Indiana
    6,101
    I bought the Beall wood threading kit and it came in yesterday so of course am playing with it today!! I see a great need for a router with a micro adjustment on it. So have narrowed it down to a pair of routers as it will probably stay on the wood threading jig. Here they are:
    A Bosch 1 HP Colt Palm Router
    http://www.lowes.com/ProductDisplay?...1&cmRelshp=sim
    A DeWalt 5 Amp Fixed Heavy-Duty Compact Router
    So, if I read correctly, both have the micro adjustment on them. (even though the DeWalt is a fixed base?)
    So how does the 1 HP rating compare to the 5 Amp rating? I just don't know how to finish the comparison and decide. I guess I am leaning towards the Bosch. Anyone have any suggestions? They are to closely priced to worry about that.
    Jon
    Jonathan,
    A 1 Hp motor draws aproximatly 10 ampsat 110 V depending on the effency. so the 5 amp would be about 1/2 Hp.
    Cedar Rapids, IA
    170
    Based on Mfr spec sheets, they both utilize 5.6A motors. The Bosch does offer variable speed. Otherwise, I'd suspect it's a wash between the two.
    Quote Originally Posted by Matt Warfield View Post
    Based on that then they lie about the colt being 1 HP. But thats normal...
    17,475
    pat warner has a good review of the bosch colt jonathan,, i have one and like it, also have PC310 which is better but not available easily now..
    Villa Park, CA
    1,407
    Universal motors are rated at stall and not at normal operating speed. Induction motors are rated at normal operating speed.
    If you were to look at the current draw at stall, it would reflect the HP rating.
    I agree it's BS but all universal motors are rated that way, which is why it's better to look at the rated current at rated RPM to compare tools. If you asked DeWalt for the HP of their tool, it would be 1HP also (probably).
    That said, I have the Bosch colt and it's a good router.
    Mike
    Ancora imparo
    Quote Originally Posted by Mike Henderson View Post
    Mike
    Your darn right it's BS. Basic Physics tells you. 1 HP=746 watts 746 watts /110 volts =6.8 amps. If the motor were 100% eff it would have to draw that many amps. and Universal motors are not very eff.
    810
    3,132
    Quote Originally Posted by John Bartley View Post
    The DeWalt is simply a yellow version of the Porter-Cable 7310. The motors, bases and adjustments are the same (same parts). Just the trim and cord placement is changed.
    I use both at work. I have a flush cutting, bottom bearing bit in the PC, and a 15 degree, bottom bearing bevel cutter in the Bosch. They both work well. My observation after two years and thousands of feet (maybe hundreds of miles even) of laminate trimming is that the PC (DeWalt) is smoother (less vibration) and easier to adjust. It also seems more rugged. I personally bought the PC when I wanted one for myself.
    John
    When i worked for midwest, we had mostly pc's.did have a few colts but no one wanted to use them enless they had to.I guess that's the reason i got the dewalt. it (to me)seemed like a better router. I also have the royobi trim router, and for what i payed it's a nice little toy.
    9,077
    I have had the Colt for a couple years or so and am very happy with it. I did get the Pat Warner bases for it but have yet to put the round one on. The offset base meets all my needs. Your needs with the Beall may be different.
    The variable speed has come it quite handy but again, if your dedicating this router to the Beall and the bits are made to run at the speed of the router, perhaps VS is not important. I would be loath to give it up but, I use my Colt for all sorts of things. I have come to totally disregard the micro-adjust. It works smoother than the DeWalt I tried but, it is still easier to adjust without it IMHO.
  1. Brought her home!
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 05-19-2014, 12:20 PM
  2. Replies: 28
    Last Post: 05-04-2014, 09:01 PM
  3. What i brought home
    By Stephen Bellinger in forum Off Topic Discussion
    Last Post: 05-16-2011, 12:39 AM
  4. I brought her home and my wife was totally cool with it
    By Mohammad Madha in forum Turning Tool Questions and Show & Tell
    Last Post: 02-16-2011, 01:50 AM
  5. Brought home some more arn..
    By Lee Thomas in forum Old Iron
    Last Post: 03-11-2007, 10:54 PM
