Results 1 to 10 of 12
Thread: New Lathe questions
    NH
    4,012
    New Lathe questions
    Ok so after spending the afternoon fixing the mini I have decided that just as soon as I can I need to get one to replace it with before I can't fix it any more.
    So which one of these to get and why?
    Jet JML-1014 Mini Lathe
    Jet JML-1014I indexing
    Jet JML-1014VS Mini Lathe
    Jet JML-1014VSI indexing
    Jet JWL-1220 Mini Lathe
    Jet JWL-1220VS 708376VS Mini Lathe
    I will be turning pens and mugs on this lathe And will expect it to work 8 to 10 hours a day when there is turning to be done.
    Or is there another kind you would recommend over the Jet and why.
    I'm thinking the 1220vs because of it's 3/4 hp motor but I heard some thing about it's vs not being all that great. But it sure would be nice to just turn up the speed instead of changing the belt.
    So what do the masses say?
    Stupid hurts.
    Chuck,
    I've got the Rikopn, 12x16 an have realy liked it I know http://www.rikontools.com/productpage_70-100.htm Bruce has one and he go rid of his jet to buy the Rikon. They also make a vs version. I have turned 12" bowls on it.
    VS, as large as you can afford. That would be my choice. The Jet 1220 would be on my list, but I'd also look at the new Delta 12" VS and whatever Rikon has in that category. The 3/4 hp motor would be an asset, in my book.
    NH
    4,012
    I have a stead fast rule with Delta.
    The Rikon has a 6.6 amp motor and I can't find the amp ratting for the Jet. Any one want to look at the plate on the motor?
    I have read that the vs robs power/torque. Any one have input on that?
    Stupid hurts.
    The Jet 12-20 is rated at 3/4 hp.
    The Delta 46-460 is rated at 1 hp.
    Ken
    Most of the small single phase VS are dc variable speed. Thus...they lose torque at low rpms. I had a Jet VS Mini 10-14....it did lose torque at low speeds but was certainly useable.
    Most of the bigger lathes use 3-phase AC variable speed. The torque is pretty well constant through their operating range of rpm.
    I will say one thing........I haven't seen the Delta 46-460.....Bernie Weishapl has the Jet........1220....has turned on the Delta 46-460 and said if they'd made them when he bought his Jet...he would have bought the Delta instead. I'm not a big Delta fan but if it's good enough for Bernie..it's good enough for me.
    Ken
    North West Indiana
    6,099
    Oh man this is starting to sound like the ratings on the palm routers. I don't have a VS, but my JET minis are workhorses. The kids at school turn on them every day, this semester two hours a day. Up to four hours a day in the past each school day. Sorry I can't be of more help.
    Jon
    NH
    4,012
    Quote Originally Posted by Ken Fitzgerald View Post
    Thanks Ken do you know what the amp's are?
    Stupid hurts.
    new york city burbs
    10,188
    chuck, hop in your truck and drive down. You can play with my 1220 VS as much as you want and give it a test run for yourself.(Ive hardly used it) I have enough chunks of wood to practice on. (while your here you can help me fine tune the bandsaw for alot of resawing I need to do)
    Central Illinois
    936
    Hi Chuck. I don't know if you have a Woodcraft close, but they should have a Rikon to test. As Don said, I have a Rikon, and wouldn't trade it for any of the jets you list. Mine is not vs, so if you want vs, I believe that Rikon would still be my first choice. Out of the several hundred we sold, I can only remember two or three small problems, which were taken care of with speed and courtesy.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
  1. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  2. Grizzly lathe G0698 discontinued vs New Grizzly lathe G0733 Both 18"x 47"
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 12-29-2011, 03:23 AM
  3. VFD & lathe tool base questions.
    By Bart Leetch in forum Turning Tool Questions and Show & Tell
    Last Post: 01-27-2010, 10:31 PM
  4. tabletop lathe, and a couple of questions
    Last Post: 09-03-2009, 08:28 PM
  5. Lathe questions
    By Yann Arbour in forum Turning Tool Questions and Show & Tell
    Last Post: 04-06-2008, 07:27 PM
