Results 1 to 6 of 6
Thread: Broke My Vessel
    Palm Springs, Ca
    1,169
    Broke My Vessel
    Started off today with a large blank in the lathe but due to bad spots etc- I end up having to make it shorter than i originally wanted. Ended up with a long tennon area due to the punky and bad areas.
    Pictures below
    During the hollowing i heard a strange sound and shut down the lathe quickly. I noticed that in on are near the widest part I had almost cut thru the side. Almost,...meaning that all that was showing was a small crack about 1/3 the way around it. I figured i would try to save it for the heck of it and see what happens.
    Decided to apply some CA glue on it and let it dry. Then applied some more and sanded it in quickly. I got lucky as you can see the crack was filled in and does not show. At that point I applied two coats of CA over the whole vessel - sanding with 400 between them (thinking I have nothing to lose at this point).
    After drying i sanded down with 400 again until very smooth. Then applied 50/50 laquer and laquer sealer x 2 coats...........
    Hopefully it will come out ok .............a design opportunity
    I'm glad you saved it Dan, looks like a nice piece!
    Nice save, Dan. What kind of wood is it?
    North West Indiana
    6,099
    I thought you said you broke it! Man that is sweet!!! I thought your first post was the before and so I scrolled looking for the post with pieces laying all over. Very nice vessel!
    Jon
    Palm Springs, Ca
    1,169
    Thanks to all - I think the wood is some type of pine but im not really sure - my gardner drops off a pc of wood now and then for me that i add to my pile of blanks.............
    Goodland, Kansas
    4,834
    Nice save Dan on some pretty wood.
    Bernie W.
  1. Broke in the blasting cabinet
    Last Post: 06-01-2016, 03:19 AM
  2. broke my bandsaw...
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 07-19-2014, 03:32 PM
  3. How did THAT happen!? (broke CMS fence)
    Last Post: 02-15-2009, 01:17 PM
  4. I broke my teeth on the table saw
    Last Post: 12-01-2008, 04:09 AM
  5. Broke Back Deer Camp
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 11-16-2007, 12:36 AM
