Results 1 to 10 of 12
Thread: If any one needs sanding stuff
    NH
    4,003
    Give this guy a try. http://www.nicks.ca/sanding.html
    I have not yet used him but let me tell you a story.
    I emailed him the other day asking for some sanding mops. This is what I got for a reply.
    Chuck
    Sanding mops are meant to sand surface profiles not a flat surface in a hole. You need to use a sanding drum I think. The drum would also have to be smaller than the hole, probably no bigger than 2" or 2 1/2" in your case and 7" long so you can walk it around inside the hole. The other alternative would be something like a cylinder hone with 3 pads. Actually that would likely work the best. Make a cylinder from wood with a shaft in it that would fit your drill. I would use soft wood to keep the weight down for balance purpose, something like bass wood. Either cut slots lengthwise on four opposite sides or flats on four opposite sides and attach pieces of emery cloth using screws to secure them creating a flap wheel. In other words in order to sand a cylinder the paper/cloth must run parallel to the surface not at right angles as is the case with a sanding mop. Seems to me I have even seen some of the cheaper cylinder hones use emery cloth this way. Check with local auto stores or tool dealers
    Hope this helps.
    Nick
    Any guy that turns down a sale for a happier customary is in my book.
    So on his advice I went to tool making.
    I took an old hone and knocked the stones off. Then I attached strips of maple with epoxy and rivets. Put some self stick Velcro on and no have a mug hone.
    Second pic before honing
    Third pick after honing for about all of 30 seconds.
    Now all I have to do is get some hook & loop sandpaper. I used some stuff I had laying around to give it a test.
    Attached Thumbnails Attached Thumbnails tn_mug7 003.JPG   tn_mug7 004.JPG   tn_mug7 006.JPG
    Stupid hurts.
    Central Illinois
    936
    You been polishing engine cylinders?
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    12,245
    I am with you Chuck. This guy is a vendor of note with a reply like that. He deserves all the success that comes his way. I will bookmark his site.
    Thanks.
    Hey he is in Canada.
    Contoocook, NH
    129
    Are those mugs going on sale soon? To save on shipping I'll even pick 1 or 2 up. I live just a few miles away.
    Richard "Butch" Leshner
    NH
    4,003
    Quote Originally Posted by Richard Leshner View Post
    They should be done in a month or so
    Stupid hurts.
    NH
    4,003
    Quote Originally Posted by Bruce Shiverdecker View Post
    Bruce
    In a past life yes.
    Stupid hurts.
    5,167
    What a cool idea!
    Wonder if I have a cylinder hone left over from my car racing days.....
    Great story, and a great bodge Chuck!
    North West Indiana
    6,097
    Question, will you be getting the inside surface so slick that your epoxy will not bond as well? Definitely more surface area and bonding available on the rough surface.
    Jon
    30,002
    Bummer...it looks like your sandpaper guy is going out of business. Although after 30 years, maybe he just wants to retire.
  1. Sanding
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 12-28-2011, 07:46 PM
  2. Sanding
    Last Post: 11-05-2010, 03:49 PM
  3. Wet Sanding
    Last Post: 08-26-2010, 01:03 PM
  4. Tip on Sanding
    Last Post: 07-09-2010, 06:57 PM
  5. sanding help
    By Craig Feuerzeig in forum General Woodworking Q&A
    Last Post: 12-31-2006, 01:52 PM
