Results 1 to 10 of 12
Thread: drawing ogees
    5,167
    drawing ogees
    What is the methodology to drawing ogees in SketchUp? Thanks.
    12,247
    Carol I would put out a pm or email to Dave Richards. He has a blog and is a contributor to Fine Woodworking and incredibly helpful in the Sketchup Department.
    I aint got it right to draw anything in Sketchup let alone even think about how you do ogees.
    http://www.finewoodworking.com/profile/DaveRichards
    Dave is a member of our forum and recently posted his project on Jeffersons bookstand.
    Calling Dave to the stand
    Ya mean like this ? Click image for larger version.
ID:	42520 two lines connected by an arc.
    How about a double Click image for larger version.
    5,167
    Thanks, Rob, I am hoping Dave will jump in.
    Don, I am looking for the methodology. I know what they look like. I have a defined distance and height. I need to know how to determine esthetically pleasing proportions of the convex and concave curves. Are they equal or some proportion of each other? Where is the center of circle the radius is taken from?
    Example: If I drew an isosceles triangle, offset the edge of the base and the height, where along the new hypotenuse would the centers of the circle from whose ark I get the curve lie?
    Bellingham
    2,449
    Carol, I found the following which explains how to draw an ogee. Look at figure 4-41. The only thing it does not explain is how to determine the ratio of the large curve to the smaller curve. The golden rectangle ratio?
    www.tpub.com/content/engineering/14069/css/14069_150.htm
    5,167
    That was very helpful, Bill. THANKS!
    Bellingham
    2,449
    Your welcomed Carol. I just checked and the curve shown is based on the Golden Ratio. The distance from point B to C multiplied by the golden ration (1.61803399) gives you the distance from point C to A. So knowing the distance between lines A & B, you should be able to reverse engineer where point C should be.
    SE Minnesota
    2,524
    Carol, it is only a coincidence that I just looked in right now.
    Thanks Rob for the nice words.
    I guess I was answering the wrong question. Sorry.
    5,167
    Dave, I didn't see you answer to the "wrong" question." Did you delete it?
    And did you have a Sketch-Up drawing process answer to my question now that I have Bill's resource for drawing lovely ogees?
  1. back to the ol drawing board....
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 06-30-2015, 04:12 PM
  2. Drawing a Waterwheel?
    Last Post: 01-26-2013, 03:48 PM
  3. New Device for Drawing
    Last Post: 08-23-2008, 05:28 PM
  4. Exploded Drawing
    By jim crockett in forum Designs, Plans and Sketches
    Last Post: 02-14-2008, 08:01 PM
  5. Sketchup drawing for island
    By Donnie Cherry in forum Flatwork Project Showcase
    Last Post: 05-19-2007, 01:49 AM
