Results 1 to 10 of 16
Thread: electric chainsaws
    5,173
    electric chainsaws
    Anybody using small electric chainsaws in their shops to trim turning blanks?
    Any suggestions?
    Yup, got mine at home depot several years ago. Click image for larger version.
ID:	42639 $70 and it work very well.
    5,173
    A 16" bar?
    Ya gonna cut blanks over 32" ?
    Nov 2008
    Tampa & NC
    432
    Electric chainsaws
    YUP,just make sure you keep oil in em an the chain sharp,OH YES and your wood is secured.I use one quite a bit when I'm down in Tampa.
    NH
    4,006
    No All my chainsaws are cordless
    Stupid hurts.
    I've got a 16" Poulan that a friend gave me because it wasn't cutting well at all. I sharpened the chain, and it still didn't cut worth a darn. Then I turned the chain around and pointed the teeth in the right direction, and it works pretty good. I wouldn't want to use it to cut a 16" blank (and no way would I bury the nose trying to cut anything bigger -- not only is it unsafe, it's real hard on the saw), but it's been handy for trimming corners and high spots off of blanks that are too big to wrestle on the bandsaw. For cutting blanks from logs, I still prefer my cordless Stihl MS390.
    From what I've read, it appears Stihl makes a very good electric, as does Makita and several other brands. For my infrequent use, a Borg-level saw like the Poulan or Homelite will probably be all I need.
    I've got a little Makita and a large Shindaiwa, they both really do cut wood, if the chain is sharp, and while they are NOT cordless, they don't stink the Dungeon up either (Yes, I've run my big Husky down there......... ONCE..... )
    One small point, the chain oil used in the electric chainsaws is different than the two-smoke saws, it is thinner, no motor heat to warm it up.
    810
    Quote Originally Posted by John Bartley View Post
    Carol,
    Just a note on safety if you don't mind. Just because it's electric doesn't mean it's any less dangerous than a gas model. Electrics are geared, direct drive, unlike their gas counterparts which are centrifugally clutched, and because they tend to work at much slower rpm's they make up for the speed with power from that gearing. If I remember correctly, safety clothing (pants etc.) which are rated for gas chainsaws don't make the grade for electric, simply due to the slowness of the chain and constant power produced the direct drive.
    Work safely eh?
    PS : as a Stihl dealer I sold a few of their electric models - they were excellent quality saws and performed very well, but were very expensive.
    Yep, what John says it true, I still wear my chaps and mitts etc, as I think they are better protection than just jeans
  1. Are chainsaws supposed to leak oil?
    By George Conklin in forum Turning Tool Questions and Show & Tell
    Last Post: 07-29-2016, 03:23 AM
  2. Finally Chainsaws!
    Last Post: 07-08-2014, 05:27 PM
  3. More Wood Has Come My Way........Get Out The Chainsaws!
    Last Post: 04-17-2013, 12:06 PM
  4. Electric & Air
    Last Post: 01-24-2007, 12:20 AM
  5. Electric & Air
    Last Post: 01-23-2007, 02:09 PM
