Results 1 to 7 of 7
Thread: Shellac on Mesquite
    Palm Springs, Ca
    1,169
    Shellac on Mesquite
    Decided to compare two different finishes today to see which I like better on the mesquite wood I have been turning. I have never used shellac and decided to give it a try today.
    Picture 1 - shows both side by side...........On the left is a bowl that was finished with just 2 coats of amber tinted shellac and currently 1 coat of gloss laquer.....On the Right is a vessel with 2 coats of light walnut danish oil
    and currently with 1 coat of gloss laquer
    Picture 2 - Close up of the shellac bowl
    Picture 3 - Close up of the Danish oil vessel
    The picture sure does not show how nice the tone came out using the amber shellac but I think im going to like using it.....Possibly the next time ill try using both the oil first followed by a couple coats of the shellac.....its just fun experimenting with different finishes......searching for that perfect finish still.............LOL
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    I vote for the shellac. The grain seems to be clearer to me.
    Tellico Plains, Tennessee
    4,381
    Me too, the finish looks sharper and clear with more gloss.
    That said, my wife hates me to put gloss on anything... she like the more satin look.
    Chuck
    Tellico Plains, TN
    17,515
    i can see the amber in it and the other seems to be less definative in the grain appearnce.. my vote is the shellac first.
    30,228
    Did you wet sand the DO version? If so, I suspect that might be why the grain is more pronounced on the shellac version. In my experience, wet sanding with oil on raw wood tends to muddy up the figure a bit. The shellac version does look better to me too, but be aware that shellac isn't as durable or resistant to water spots as the various poly or varnish/oil blends.
    Goodland, Kansas
    4,834
    The shellac looks good but I have to agree with Vaughn for how long. Shellac is not durable at all. I now only use it on my small turnings. Bird houses, ornaments or lidded box the top with gloss lacquer.
    Bernie W.
    Palm Springs, Ca
    1,169
    I sprayed the laquer over the shellac so i was hoping that would give the durability to the finish................
    The Danish was wet sanded in both coats.....then the laquer sprayed over that...........
    Wondering if apply the shellac over the danish if ill get the same tone in the wood........................more experimenting ahead i see......lol...
    thanks Dan
  1. shellac flakes?
    Last Post: 12-17-2012, 12:26 PM
  2. Question on shellac
    By Sal Cangialosi in forum Finishing School
    Last Post: 11-05-2011, 01:47 AM
  3. shellac
    By Rex Bloem in forum Finishing School
    Last Post: 03-17-2011, 03:12 AM
  4. Formbys on Shellac??
    By Jiggs Elphison in forum Finishing School
    Last Post: 09-17-2009, 11:41 AM
  5. What's up with my shellac?
    By M Toupin in forum Finishing School
    Last Post: 07-28-2007, 04:21 AM
