Results 1 to 10 of 17
Thread: Joinery Design Question
    SE Minnesota
    2,550
    Here is a table I've been working on. It is based upon the Thos. Moser American Bungalow Square Extension Table. I've been thinking about the joint between the top of the legs and the upper rails and I'd like your thoughts.
    Here's a view from below.
    And a closeup of the way I drew the joinery.
    My thought is that rather than cut the rails in pairs, ie. a front/back pair and a left/right pair, I would make them all identical so that they sort of chain together. The legs would all be identical as well.
    The table is an extension table with a single center leaf. I'm not certain yet how the top attaches to the base. I suppose I need to figure out how the extension part works first.
    Anyway, I'd appreciate your views.
    D
    Nova Scotia's beautiful south shore
    443
    That's some ambitious joinery. I think you've come up with a reasonable solution for the interlocking rails and table legs. I'll leave to others to make suggestions for those joints.
    The extensions are generally nested sliding dovetails with stops. I couldn't find an image on the web - a good furniture book should have drawings.
    How to go about attaching the top rails to the underside of the table is very tricky. You could anchor on only one side of the joint in the top, but that would be flimsy and the legs would be off center when the leaf was in. You could think of using dowels protruding from the bottom of the table top to rest in sockets in the rails. Then you would need to lift the top free from the base for opening and closing. One set of sockets for closed - another for open. Not the most secure setup.
    More typical extensions work with rails or aprons that are cut in line with the joint in the top. They stay fixed to each end of the table - allowing the legs to move equally from the center point as the table is opened.
    So I guess I'm not helping you find your solution. I can point to the source of the problem, though. Your rails and extensions are shown separate from each other when it would be much simpler to combine them.
    All the best,
    Ian G
    **Now holding auditions for a catchy new signature**
    SE Minnesota
    2,550
    Thanks Ian,
    I think the rails you're referring to are more decorative and perhaps for stiffening the top. The center leaf has a matching rail added, too. The extension mechanism isn't drawn in yet. I can see something it one of the photos of the original but there's not enough detail to tell exactly what it is or how it works.
    443
    Post Deleted by me.
    Last edited by Ian Gillis; 01-25-2007 at 08:24 PM. Reason: I was wrong, wrong, wrong !
    All the best,
    Ian G
    443
    Okay, the legs cannot be separated like on a typical dining table. The lower stretchers prevent this.
    Therefore I'm gonna guess that the extensions are attached flat to the underside of the top close to the aprons and that the table top has some sort of dowel or hardware that runs in a groove on top of the interlocking rails.
    So, the outer rail or apron is primarily there to hide the extensions from view. It must be cut in line with the joint on the table top. The matching apron on the leaf fills the gap when the table is extended.
    I think he must be using metal extensions because wooden ones are quite bulky and require a wide apron to hide.
    There, that was my brain workout for today
    Good luck with the project !
    All the best,
    Ian G
    Wake Forest, NC
    292
    It seems a bit complex to me. Since I have gotten addicted to sketchup (thanks to you), I have noticed I have a tendency to make things more complex than they need to be (at least for me). Don't know if that applies to you or not.
    You could make the top rails a half lap and just have a tenon on the leg coming through a mortise in the center. Just a thought.
    BTW, I like the overall design. I saw a recent episode of TOH where Nahm went to Thos Moser's shops. Very impressive workmanship there.
    SE Minnesota
    2,550
    Ian, I expect metal extension hardware would be right for this table, too. Here's a view of the table with the leaf added. I suppose the extension hardware could be attached to the rails. I need to hunt up some hardware for that.
    Travis, complex? Are you kidding? The letters after my name are PhD-OE. The "OE" stands for Over Engineer. In this case though, I was trying to think up a simple way to maintain the detail, gain some strength and make the joints as easy to cut as possible. My thought is that all four rails would be identical (Until the point of adding the extension hardware.) and I wanted the outside corner detail of the leg to be as strong as I could make it so I wouldn't break it off. Here's a close up view of the joint assembled.
    Now I'm thinking I could drill a hole in the end of the leg and fill it with epoxy, redrill and tap for a bolt or machine screw to hold it all together.
    SE Minnesota
    2,550
    Modified leg joint.
    I decided to skip having the leg running up between the rails. Now I have a single tenon and motises through the a bridle joint in the rails. Better?
    Now that makes sense to me, I've been thinking about this thread since I first noticed it. Now maybe you could put a dovetail slot in the rail for the table top to slide in. Then a matching slide on the table top to keep the top in alignment when you open it..
    SE Minnesota
    2,550
    Hey. that's an idea worth exploring, Don. Thanks.
  1. Design Question
    Last Post: 11-02-2013, 02:17 PM
  2. Another Design Question
    Last Post: 08-07-2012, 02:41 PM
  3. Newby question and pocket hole joinery
    By Leo Wirtz in forum General Woodworking Q&A
    Last Post: 02-07-2011, 06:36 PM
  4. Joinery Question for pulpit base
    By Stephan Postmus in forum General Woodworking Q&A
    Last Post: 10-20-2008, 01:34 PM
