Results 1 to 10 of 21
Thread: Installing Stair Treads
    13,427
    A friend's wife has ripped out all of the carpet on their stairs to their basement and is wanting oak treads installed. It currently has the particle board treads and plywood kick boards installed.
    I plan to remove at least the existing treads and perhaps the kick board depending on the clearance.
    My question is...I'm planning to use constructions adhesive to install the treads and kick boards with only a few nails to keep them in place. Is this acceptable?
    you'll be relying on glue to hold to what amounts to endgrain if the stringers are cut from dimentional lumber.
    Austin, Texas
    1,447
    I am facing what will probably be the same problem... carpeted stairs, presumably junk lumber underneath, no access to the underside of the stairs. I want to put on oak treads (and probably new risers too), so what is the best way to attach? Once the old tread is up, I could screw a sister to the stringer if the grain is the only problem with glue, but is there a better way?
    Charlie Plesums, Austin Texas
    NH
    4,003
    Glue, screw and plug or glue nail and fill. You have a pile of other options depending on your skill set but those two are going to be the easiest.
    Stupid hurts.
    13,427
    I guess I was more thinking that the glue would help with squeaks and such over time. I don't mind using nails to attach the treads. Most likely I'll be removing the old and attaching directly to the stringers. Typically I'd do probably 3 nails on each stringer, one hidden by the riser, and two others on the face. Would the glue cause more problems than it's worth?
    5,317
    Actually, that particular glue & nail combination should be okay, and the glue should definitely help with the squeaks. My construction adhesive of preference is PL Premium, BTW.
    NH
    4,003
    Now this brings up the age old question riser on top of tread or riser behind tread?Well I know what I do and why, but lets hear from you guys which way and why?
    Stupid hurts.
    if you're going to build to last there are a couple of ways to strengthen the stringers and make them ready for glue.
    the most labor intensive is to let in a 2x across the face using glue and nails/screws.then add sleepers parallel to the treads behind the 2x.
    then i like to use plugged screws and more glue to affix the treads, face to edge grain.
    like jim i too use pl premium.....(don't slop it on your finished wood!)
    if you're going to mill your own treads/risers be sure to plow a stopped dado in the bottom side of the tread and cut an appropriate tongue on the riser, that way you won't need a scotia mould.
    i try to glue and screw the riser into the back of the tread below it. providing i can access the back.
    Or you can do it the way Sam Maloof did Click image for larger version.
ID:	42737 without any risers.
  1. Vinyl Stair Rails
    Last Post: 07-12-2013, 05:20 PM
  2. A Replacement Stair Baluster
    By Roy Bauman in forum Lathe Project Showcase
    Last Post: 08-23-2011, 01:01 AM
  3. Stair Question
    By Vaughn McMillan in forum Carpentry and Construction
    Last Post: 08-03-2011, 08:25 PM
  4. Stair cases
    By Al killian in forum Designs, Plans and Sketches
    Last Post: 12-31-2010, 03:21 AM
  5. Stair case routing
    By Fred Pilkington in forum Jigs and Fixtures
    Last Post: 03-09-2007, 12:05 PM
Tags for this Thread
