Results 1 to 7 of 7
Thread: Didn't take long to get in trouble
    Been self learniong woodworking over the last few months. As a simple project, I built a narrow cabinet to house/hide an old intercom system. All went well until the door. It is a sinple overlay on a face frame. The frame of the door will hold speaker cloth instead of a panel. Here's where I got over my head.
    I used a router bit with a bearing to create a 3/8" rabbet around the inside edge of the door frame. The idea was to create a ledge to attach the speaker cloth to and them place some kind of molding over it to clean up the edge. What I didn't realize is that the bearing naturally created rounded corners. Those that know what they are doing will tell me no problem; but I have been struggling with deciding how to deal with those rounded corners and install the molding. Some ideas that came to mind are:
    - Chissel it square - Not sure I trust myself at that
    - Carve out the underside of the molding to overlap the curve and thus square it
    - Try two parts to the molding. One to fill the rabbet and the other to overlap the first and the curve.
    I am proabably writing too much; but would appreciate any advice from the experts out there
    Thanks in advance
    Sal
    Sal Cangialosi
    NH
    4,006
    All of the above will work just fine. Go with the one you feel most comfortable doing. Then try the others on scraps just to sharpen your skills.
    I would go the chisel the corner square route.
    Stupid hurts.
    Quote Originally Posted by Sal Cangialosi View Post
    That would be my choice. A nice sharp chizel.
    Dec 2008
    falcon heights, minnesota
    5,610
    that's what i do with my picture frames, chisel it square. there are corner chisels made for just for this.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Add another vote for chiseling it square. Just take small bites, and it should be pretty easy. You can use a straight edge and an Xacto or utility knife to mark the line where you want to cut, then work your way up to that line a little at a time. I think you'll be surprised how easy it is.
    I'll also second Chuck's suggestion to try all the methods you listed on scrap materials, if for no other reason than the experience.
    Long Hill Township, NJ
    467
    You not in trouble - your just being tested!
    Ditto on the advice already given.
    Cheers
    Jim
    Thanks
    As always, thanks for the replies. I'll take the advice on using a chisel to get the corners square. sghould be a good test of patience
    Thanks again
    Sal
    Sal Cangialosi
  1. Well That didn't last long
    By Ned Bulken in forum Lathe Project Showcase
    Last Post: 09-23-2014, 02:59 PM
  2. Replies: 1
    Last Post: 09-19-2014, 04:50 PM
  3. Stair modification complete! Why didn't I do this a long time ago?
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 03-16-2013, 04:43 PM
  4. Ever really wish you didn't
    Last Post: 07-16-2011, 02:08 PM
  5. Purpleheart: How long, O! lord, How Long?
    Last Post: 02-28-2007, 03:38 PM
