Alex Reid
- Zushi, Japan
I was thinking recently about joint stregth and took a look at FWW to see what they had to say. I found the following test and poll.
Here are the results from a Fine Woodworking test on joint strength using a hydraulic press. The press stress tested for racking on a 90 degree joint constructed of 3/4 thick x 2.5 wide x 8 long inch cherry stock. Placing the stock on an end-to-end diagonal and applying vertical force down to the breaking point of the joint.
1. HALF LAP 1,603 lb.
2. BRIDLE 1,560 lb.
3. SPLINED MITER 1,498 lb.
4. 3⁄8-IN. MORTISE & TENON 1,444 lb.
5. 3⁄8-IN. FLOATING M&T 1,396 lb.
6. MITER 1,374 lb.
7. 3⁄8-IN. WEDGED M&T 1,210 lb.
8. 3⁄8-IN. PINNED M&T 1,162 lb.
9. 5⁄16-IN. M&T 988 lb.
10. BEADLOCK 836 lb.
11. DOWEL 759 lb.
12. ¼ -IN. M&T 717 lb.
13. POCKET SCREW 698 lb.
14. DOMINO 597 lb.
15. BISCUIT 545 lb.
16. BUTT 473 lb.
17. COPE & STICK 313 lb.
18. STUB TENON 200 lb.
And here are the results of a readers poll in FWW forum Knots on the the strongest joint
1. M&T
2. Half Lap
3. Bridle
4. Pocket Screws
5. Floating tenon
6. Other
7. Miter
2. BRIDLE 1,560 lb.
6. MITER 1,374 lb.
11. DOWEL 759 lb.
14. DOMINO 597 lb.
15. BISCUIT 545 lb.
16. BUTT 473 lb.
1. M&T
2. Half Lap
3. Bridle
4. Pocket Screws
5. Floating tenon
6. Other
7. Miter
