Results 1 to 1 of 1
Thread: VFD & Motor close on the horizon
    3,134
    Well I am looking into a turn key VFD & Motor system that I can mount plug in & start using Put together by the Motor shop I've done business with for years. I figure that I can use this on my Delta Double duty lathe Until I get ready & then build my own bowl lathe & move the VFD & Motor to it.
    I like the Delta 46-460 but I also like the Delta double duty lathe I have now & it allows me to be able to turn on the outside of the head which will make it possible to turn bigger then 10 1/2" - 11" that can be turned over the bed ways & bigger then the 12 1/2" of the Delta 46-460.
    So if this VFD & motor system has the slow power I need I can turn the way I want too & save up to build a bowl lathe.
  1. Not Done with it yet, but getting close....
    By Chuck Ellis in forum Turning Tool Questions and Show & Tell
    Last Post: 04-13-2015, 04:06 PM
  2. Flames on the horizon.
    Last Post: 07-05-2013, 11:28 AM
  3. Somewhat gainful employment on the horizon
    Last Post: 02-09-2013, 10:58 PM
  4. Another interview on the horizon
    Last Post: 12-29-2012, 08:24 PM
  5. New tool steel on the horizon
    By Matt Ducar in forum Neander Woodworking Q&A
    Last Post: 10-24-2012, 03:02 PM
