Results 1 to 10 of 11
Thread: Pencils
    Yorktown, Virginia
    5,022
    Pencils
    I see beautiful pens being posted frequently...pencils not so much. Here are some mechanical pencils done using a process that's been around for many years. The 'innards' from commonly available Pentel mechanical pencils are used to create custom pencils from materials of your own choosing. A step drill (the one shown is 17/64 with a 1/2" long 'step' down to 1/8") is used to drill the blank, which is slipped over a pen mandrel for turning. The tip screws onto the brass threads which protrude through the 1/8" step drill hole. The rest of the 'innards' bottom out on the shoulder of the step, so screwing on the tip locks the whole thing in place. Shown from left to right are: The Pentel pencil (9mm for my heavy hand, but you can use any lead size--they all work), the step drill, and pencils in Cocobolo, Padouk, Bloodwood and Corian. Not that anyone needed anything else to turn.....
    Incidently, these pencils cost an arm and a leg in office supply places. You can find them on line in quantity for much cheaper
    Last edited by Darren Wright; 10-27-2016 at 03:37 AM. Reason: trying to show attachments.
    S E Washington State
    3,777
    Some real nice work. Where do you get a step drill like that? Internet? Again nice work.
    Feb 2009
    Whittier, CA, USA
    512
    Very nice.
    The Pentel is my favorite "pencil". Thanks for posting.
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    Very cool, Ted. I hadn't seen that approach for pencils. I used to use a 0.5mm Pentel all the time when I was taking a lot of handwritten field notes. Yours are nice upgrades.
    Yorktown, Virginia
    5,022
    Paul...I bought two of these drills years ago from Craft Supplies--which I don't think carries them anymore. I found a couple of places that sell them but I don't know anything about the companies and haven't ordered from them, so caveat emptor.
    http://www.theperfectcollection.com/...e5b0df32f10819
    http://www.wlfuller.com/html/special_drills.html
    Also, on another forum, Marvin Hasenak wrote:
    "You can do these without the step drill. Drill the blank to the depth with a 17/64", then take the blank and mount it on a 1/4" drill rod. Put the end of the drill rod in a collet chuck and use a drill chuck in the tailstock with the 1/8" bit, not sure I use a 1/8" I think I use a 5/32" The drill rod will line up the holes. You may need to use a little cellophane tape as a shim to get a good fit on the drill rod. Usually the wood swells just enough to give a good fit. "
    I found that a plastic drinking straw, split lengthwise took up the slack on my pen turning mandrel.
    lutefisk capitol, USA
    485
    A good machine shop should be able to make the step drill for you. I had a bunch made by a shop in South Carolina. I can find the web site when I get back to my other computer if any interest.
    11,834
    Neat and clever. Unique also.
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Nicely done Ted!
    Great selection of timbers.
    Pencils are not sellers in my area.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Yorktown, Virginia
    5,022
    Thanks Les. These are give-aways. I work with engineers and architects--they love 'em
    Jul 2007
    Des Moines, IA
    854
    Those are really cool. I might even try one of those.
  1. Turning Pens and Pencils
    By Barry Stratton in forum Old Ads
    Last Post: 03-01-2011, 12:49 AM
