Results 1 to 10 of 12
Thread: Cyclone dust bin sensor
    Central PA
    638
    I, like several (at least) have a Bill Pentz design cyclone. What do you guys use to tell you when the bin is full. I had the bin fill at least 3 times in the past month and blow dust all over the shop. I saw on Bill's site there is a plan to make a sensor from a solar powered motor with a fan blade, He also said that you could use a regular photocell and christmas light bulb in the pipe right above the bin to trigger an alarm or light or whatever. Any thoughts?
    Well Dave I just look at the clear flex hose that connects the dust bin to the cyclone. When I see chips start to constantly swirl around in it I know it's time to empty the dust bin. When that happens I usualy have about 5" of empty barrel left.
    Thomasville, GA
    5,992
    Ditto on Alan's process.
    Bill Arnold
    My cyclone (clear-vu) unit -- cyclone, dust bin, filters are located in a closet.
    For noise abatement.. I screwed up and let it overfill and the center of the filters were packed (really packed) with waste. What a mess -- lots of work clearing them.
    So I also would be interested in a light type system that I could put outside the closet or a doorbell noise maker.
    If you find a system that works please let me know..
    Please!
    Paul
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Cedar Rapids, IA
    170
    While I never fully had mine setup, my plan was to have the collection can on a mechanical scale. That way I could empty it before it got heavier than I wanted to lift. But, never got there so don't know how effective that would've been overall.
    Central PA
    638
    I forgot to mention that its in another room, I can see through mine, its polyethylene plastic so its translucent like a milk jug, but its still in another room often behind a bunch of junk so the take a look method doesn't work well for me. I am thinking about trying the photocell method.
    Central PA
    638
    Quote Originally Posted by Matt Warfield View Post
    I read of someone who tried that but if they are planing the drum will be light when its full and if you are sanding or cutting it will be heavy when not even full so the scale method is relative to what you are doing.
    Central PA
    638
    Heres something I found that looks good.
    http://www.crowsnest.us/woodshop/tools/cyclone.htm
    I'll see what else I can find
    Thanks Dave====
    That looks like it is right on --
    Now to get it done along with about 20 other things to do...
    Thanks -- well done
    paul
    still sings!
    2,784
    There is a post over at the Clear Vue Forum of schematic and parts list for making one. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
  1. Dust bin level sensor, $99
    By fred hargis in forum Hot Deals
    Last Post: 05-28-2016, 11:16 AM
  2. Jet 1642 Digital Readout Sensor
    Last Post: 10-03-2012, 11:55 PM
  3. Cyclone dust bin level sensor
    Last Post: 06-27-2012, 12:23 AM
  4. Miter Saw/ RAS dust collection, vac or cyclone
    By Dave Black in forum Jigs and Fixtures
    Last Post: 08-09-2011, 10:20 AM
  5. My cyclone dust control system clogged up. Why?
    By Frank Pellow in forum General Woodworking Q&A
    Last Post: 03-12-2007, 02:10 PM
