Results 1 to 7 of 7
Thread: Angle grinder at Harbor Freight
    Palm Springs, Ca
    1,169
    I see that there is a angle grinder 1/4" made by central pneumatic on sale at HF for 12.99 - I am wondering if it is any good for sanding on the lathe and wondering if anyone else is using it ?
    Currently using a elec drill and works good also..........thanks
    11,831
    An angle grinder would be real high speed for sandpaper use. Not good, IMHO. Stick with the drill.
    13,360
    I think a few of us on here have this drill that we use on the Lathe. I think they have a couple of version of this at HF
    http://www.harborfreight.com/cpi/cta...emnumber=92956
    30,014
    Dan, I'll echo the other guys. I think the angle grinder would be too fast (I don't think it's variable speed). It'll also make your compressor run pretty much full time, and since it doesn't have a regular chuck, you'll likely have trouble getting sanding pads to attach to it.
    I know it's a lot more money, but here's my pneumatic sander of choice:
    http://www.woodcraft.com/Catalog/Pro...x?prodid=21993
    I also use one of the corded right angle drills from Harbor Freight a lot, but use the Grex to remove the sanding marks from the drill.
    I have that angle grinder, and have used it for welding for a couple years now. It's a nice one, but not sure for wood.
    Palm Springs, Ca
    1,169
    Thanks for the clarification - ill look into the two mentioned......Dan
    I got one of those a while back, it lasted 3/4 way through a project. Had to finish another way. Later I got another one, A couple of uses later it smelled and smoked as well... I now have a quality one that cost a good deal more money but it lasts and gets the job done, I wasted my money trying to cheap my way through.
    As for the sanding on a lathe, The name itself defines that answer. "Angle GRINDER" Do you want to Grind your projects or smoothe them ?
    Too fast, too aggressive, spend your money on the right angle drill, Pay more and expect it to last. HF has a right angle drill as well as a right angle attachment for a drill.
  1. Harbor freight.
    Last Post: 05-09-2017, 10:42 PM
  2. Harbor freight coupon
    Last Post: 04-25-2014, 03:02 AM
  3. Harbor Freight Coupons
    By Dan Mooney in forum Hot Deals
    Last Post: 07-24-2012, 01:14 AM
  4. Harbor freight 15% off
    By Don Baer in forum Hot Deals
    Last Post: 12-22-2009, 03:55 PM
  5. Harbor Freight bandsaw
    By Dennis Thompson in forum General Woodworking Q&A
    Last Post: 07-07-2008, 12:19 PM
