Results 1 to 10 of 16
Thread: Ferroconcrete?
    Dec 2009
    Madison, WI
    206
    Ferroconcrete?
    Is anyone here familiar with ferroconcrete construction? I've got a few projects that might make use of it, but I'm a bit confused as to where to start.
    4,553
    Joseph do a Google search for ferro concrete construction you might do a search on youtube also. I have seen some videos of it being done I think on there. They talk about it on the Barrelponic forum I go too and also the aquaponics folks use it sometime too.
    Jay
    A Turn N Time
    Frog Pond Guitars
    Villa Park, CA
    1,407
    What is Ferroconcrete? When I search for it, I keep coming up with reinforced concrete, which is just concrete with reinforcing bars.
    Mike
    Ancora imparo
    Mike, try Ferro Cement. I saw a boat made of it when I lived in the Islands. Here a link showing some stuff built with the technique.
    13,363
    Liberty Ships were made of Ferro-Cement in WWII.
    It's basically what it sounds like, Reinforced concrete molded into shapes. Some of those shapes make boats.
    There are even contests for College engineering teams where they race small boats made out of ferro cement. Using various materials, they are able to make some pretty fast, light boats out of 'concrete'. I'd bet Jeff would have some more info on how fast they are, but I doubt they could compete with his kayaks...
    No experience with the type used for boats and such. When I saw ferroconcrete in the thread title, I was thinking along these lines:
    http://starwars.wikia.com/wiki/Ferroconcrete
    Although that particular example is a Star Wars reference, I've worked with a similar material years ago when I was working in the testing lab. Sandia National Lab in Albuquerque was looking for a material to use for radiation shielding, and we tested a mix design that used magnetite for the aggregate instead of regular sand and gravel. It made some extremely dense and strong concrete. While the average concrete test sample (a 6" diameter cylinder that's 12" long) weigh around 30 to 35 pounds, the magnetite mix samples weighed about 70 pounds. It was also very exciting to run through compressive tests. Typical compressive testing involves putting a test cylinder in a hydraulic press and squishing it to the point of failure. Usually, the sides of the cylinder start to crumble, the needle on the gauge starts to drop (about 2/3 of the way up the dial), and you shut the machine down. Nothing too exciting. I don't recall the specific numbers, but the strongest mixes we typically tested would maybe go 3/4 of the way up the dial before the sample would fail. With the magnetite concrete, it wasn't unusual to peg the needle on the machine while the sample remained intact. And in the cases where the sample did fail, it was generally very explosive, shooting chunks of the sample to the far side of the lab. We did have a safety cage made of expanded metal to contain the bigger chunks, but I broke lab glassware 40' away with the pieces that shot through the mesh. Good times.
    13,363
    You know, I can't actually find anything that says liberty ships were ferro-cement. I've heard that before, but right now I can't find anything that corroborates that. So I retract that statement.
    But here is a link that talks about concrete ships...
    http://en.wikipedia.org/wiki/Concrete_ship
    Dec 2009
    Madison, WI
    206
    Quote Originally Posted by Jay Caughron View Post
    Jay
    I've had some difficulty getting solid answers, and was hoping to get some information from people with lots of experience actually building things. Lots of the folks on here seem to be carpenters, contractors, or just hardcore DIYers.
    Quote Originally Posted by Joseph Shaul View Post
    I've had some difficulty getting solid answers...
    Let us know what specific questions you've got, and if we can, we'll try to answer. What types of things are you considering building?
    11,833
    Yep. I wondered about that statement. I once saw a documentary on the building of the Liberty ships. They were standard iron and steel construction. Albiet, the construction was quicky and pretty flimsy. That is why few, if any, still survive.
