Results 1 to 5 of 5
Thread: Finishing up some projects
    Palm Springs, Ca
    1,167
    Day off and finished up a few projects and thought i would post the results of the different things i did with them.
    Picture 1 - is a small vessel i turned out of some california buckeye and I really didnt like how it turned out a first due to round hole in the side of it. So today i used my carving tool and enhanced the hole, painted the edges black, and buffed the CA finish by hand and it shined up pretty good. The light from the camera or room makes the inside look white but it really is a dark grey color.
    Picture 2 - Is a vessel, medium in size and i turned the finial differently this time. I made the bottom tappered so it fits in like a cork or plug. The finish is two coats of DO and 4 coats of spray laquer. I let it dry for a week and hand waxed it for the heck of it just to see if the finish improves.
    Picture 3 - Larger vessel that has two coats of DO on it and ill let dry for couple days and use 0000 steel wool to knock down a bit - then im planning on trying a new product that is made of beeswax and orange oil. More later when its complete
    Picture 4 - are 7 small segmented walnut bowls that a friend gave me that he was going to throw out. I put a small glue block on the back and put them on the lathe and sanded them down quickly - being bare wood at that point i just rubbed in really well some of the beeswax and orange oil - they came out nicely with a satin finish look to them and i know they are food safe.
    Still like experimenting with the finish work ..........................................Thanks Dan
    Attached Thumbnails Attached Thumbnails Buckeye-2.jpg   Mesquite-Vessel-Finial.jpg   Vessel-Laquer.jpg   Walnut-bowls.jpg
    Goodland, Kansas
    4,834
    Projects look pretty good Dan. Looks like you been pretty busy.
    Bernie W.
    Jul 2007
    Des Moines, IA
    854
    Very nice projects, Dan.
    3,132
    good job all around. Really like that buckeye wish i could get my hands on some down south here.
    Steve
    Palm Springs, Ca
    1,167
    Stephen...............The buckeye is from some wood i bought and I don't think I would do it again - I bought a couple large pc's and had them shipped ran me about $120 which would have been ok except the wood had alot of punky areas making alot of it unusable..............but what can I say - I usually do not buy wood but wanted some Ca buckeye bad .......ahhh well.....just be careful who you buy from.............I have had good luck from Gotwood.com and they stand behind what they sell............Dan
  1. finishing up small projects
    Last Post: 02-29-2012, 09:40 PM
  2. Wrapping up some projects and New approach to Finishing
    Last Post: 07-15-2011, 12:53 PM
  3. Finishing up more old projects
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 07-13-2011, 03:32 AM
  4. Day Off and Finishing up projects
    Last Post: 06-29-2009, 10:47 AM
  5. Projects Under Way
    By Michael Robertson in forum Lathe Project Showcase
    Last Post: 01-23-2007, 07:42 PM
