Results 1 to 10 of 12
Thread: Pendants
    Aug 2008
    Reno, Nv
    3,632
    Pendants
    Big one is Ambrosia Maple, little one is a Corian sample block. Both sanded to 600 and finished with Mylands. Enjoy!
    Yorktown, Virginia
    5,005
    Nice ones Jim. Careful who you show them to or you will be making pendants forever
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Look great Jim!
    I like what you did with the Ambrosia Maple.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Goodland, Kansas
    4,834
    Good looking pendants Jim. Don't let your wife show them around or you will be making a lot more. Don't even ask how I know.
    Bernie W.
    May 2009
    Lafayette, Indiana
    2,380
    Jim, those look good! I like the accent cuts you did on the first one. How did you like turning the Corian? I have a box full of blanks here to use but have not tried any yet. Good job.
    Tom
    Aug 2008
    Reno, Nv
    3,632
    Thanks guys.
    Bernie, those 2 are already gone. She has more planned for me tomorrow. I made a large and small sacrificial block, both out of walnut so I hope they last!
    Tom, Corian is very easy, but very powdery. Sands well to 600. I used to use it on Bottle stoppers.
    Dec 2008
    Portland, Oregon
    1,898
    I'm still having trouble finding a good double sided tape.
    Bernie mentioned 3M tape, but I haven't been able to find it yet.
    Jesus was a Woodworker
    Catalunya
    4,632
    Quote Originally Posted by Jim Burr View Post
    Unless they've changed its composition I remember making a project with corian when they first released it (about 25 years ago)and we had to use widia tools all the time, as it worn out normal steel tools in minutes.
    A table saw blade would cut only a couple of times before having to be replaced.
    I wonder if it is still like that
    Best regards,
    Toni
    Goodland, Kansas
    4,834
    Thanks guys.
    Jim when turning wood I quit using the double sided tape. With the new backer plates I just screw the wood to it and turn the pendants. To me it just saves a step or two. I figured if your wife was like mine it wouldn't take very long. I have about a half dozen to make today.
    Bernie W.
    May 2009
    Lafayette, Indiana
    2,380
    Jim, I'm using the double sided "DUCK TAPE". It has a blue outer coating on it. I bought mine at Walmart for about $4-5 per roll. I still bring the tail stock up to hold the piece while I turn it down and shape it.......then I offset it. By then it is pretty well stuck. Then I can move the tail stock back and drill and accent the front.
    Bernie....If you screw the piece to the plate...surely it doesn't have screw holes in the back of your finished piece does it???? Or are you cutting that away later???
    My backer plate does have the 4 holes drilled for screwing the waste block to it but I then use double sided tape to hold the pendant blank to the waste block.
    Tom
  1. Wood Pendants
    By Jim Krager in forum Lathe Project Showcase
    Last Post: 05-14-2015, 08:28 PM
  2. Turned pendants
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 08-30-2010, 11:10 AM
  3. Pendants
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 03-13-2010, 10:10 PM
  4. First Batch of Pendants
    By Ted Calver in forum Lathe Project Showcase
    Last Post: 03-03-2010, 10:43 PM
