Results 1 to 10 of 23
Thread: sliding compound miter saw fences
    5,167
    I have a 10" Hitachi SCMS and a Delta Universal saw stand. I want to use a fence system for reliable repetitive cuts. Flip stops would be nice.
    I am seriously considering the Kreg system but note that some extra fabrication will be required. But that seems to be the case in any event.
    So tell me what kind of fence systems you are using with your SCMS and what do you recommend? Also would appreciate knowing what to avoid! Thanks.
    BTW, pictures would even be greater!
    17,470
    if you are looking at a permanent stand carol i have the kreg flip stops on both the radial arm bench and the chop saw outfeed tables.. look at my shop thread some time back and you can see what i have..also i would suggest that you have it at a level where you can see where your cutting..i know i can measure and set the stop and be fine but fo rthe cuts that you arent sure or are only making one cut you dont set up the flip stop for it..you bend over look at the line and drop the saw to it and then hit the trigger.. so you need to have the height at a good eye level.. in my opinion and my hieght willdiffer from yours
    NH
    4,005
    I use the grip right system.
    Stupid hurts.
    5,167
    Good for short work, Chuck.
    Ever do long work?
    12,247
    13,357
    Shop notes has an interesting setup in their latest.
    http://www.shopnotes.com/issues/110/
    I've got mine on a portable stand. I attached a piece of square aluminum tubing to mine, put an an adhesive backed tape measure on it and made a little sliding wooden block. Works great for repeat cuts...
    11,827
    I use a clamp and hunk of 2x4. Not quite as fancy as Chuck's set-up.
    3,134
    Hey Chuck is that for cup's, top's or bottle stopper's?
    4,552
    Your just a high tech type of guy arent ya HUH
    A Turn N Time
    Frog Pond Guitars
    Mines like Chuck's only green instead of orange.
  1. Compound Miter
    By Jack Reynolds in forum New Tools
    Last Post: 01-13-2012, 11:35 PM
  2. compound stave miter jig
    By tom daniels in forum Jigs and Fixtures
    Last Post: 12-08-2010, 01:14 AM
  3. new makita compound miter saw
    By Dan Noren in forum New Tools
    Last Post: 10-27-2010, 12:33 AM
  4. Replies: 5
    Last Post: 03-09-2010, 04:29 PM
  5. ZCI on a sliding compound miter saw?
    By Jim O'Dell in forum New Tools
    Last Post: 06-18-2007, 11:48 AM
