Results 1 to 5 of 5
Thread: refinishing a piano
    Westphalia, Michigan
    955
    refinishing a piano
    Hi all, I bought an old grand piano at an auction and it needs refinishing. I haven't figured out how old it is but it at least predates 1940, when the company stopped production of their grands.
    The finish is blemished or deteriorated to the point where much contact causes it to crumble. I guess it is a varnish of some sort. The wood is ribbon Mahogany and I want to bring it back to it's original glory. It does look like the original finish was stained to darken the mahogany. I don't know if mahogany darkens with age or sun oxidation. There is a small piece of veneer missing. I plan on replacing that and blending it in to the old veneer.
    Other than that I might build a ribbon mahogany bench to match the piano. The bench that came with it is not the original.
    My concerns have to do with the refinishing process. The veneer looks to be pretty thin so I want to remove the finish without hurting the veneer.
    Any suggestions?
    Paul,
    Dave Haskins does a lot of piano's so I would defer this one to him.
    30,008
    I'd look at the various methods the pros use for pianos. I Googled "piano refinishing" and got a slew of hits. Here's one that caught my eye:
    http://www.pianorestoring.com/Histor...efinishing.htm
    Dec 2009
    Kemah, Tx. - Houston Suburb
    95
    The best was to remove the finish is with a chemical stripper. It will remove the finish down to bare wood and remove any old stain with it. Generally, a good stripper wont remove the analine dye.
    You can get a really nice finish straight from the gun with lacquer. If you want to get a 'piano' or mirror finish you will have to go through a process. It is lengthy, but not diffilult. I have done it by hand on small tables but for a piano, I think you have no other choice but by buffing with a buffer. Again, it is a process in which yoiu can skip any steps. A cheap buffer wont work. You will probably be looking at $250 or more for the buffer. It should have a variable speed from around 2,000 to 3,000 RPM, and enough HP to not slow down under pressure. Without a buffer, there is no way I would even do a table top.
    Apr 2009
    Outside the beltway
    5,250
    If you do a search on here you will find the way we do hand finished Pianos.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  1. Need to Piano finish a subwoofer
    By Barry Shaw in forum Finishing School
    Last Post: 12-18-2015, 12:03 AM
  2. Kalimba - aka - Thumb piano
    By Ken Cook in forum All Things Musical
    Last Post: 01-14-2014, 10:23 PM
  3. Five Guys and a Piano
    Last Post: 08-21-2012, 09:54 PM
  4. Finished Piano
    Last Post: 06-08-2009, 07:40 PM
  5. Piano Pen
    By Jon Lanier in forum Lathe Project Showcase
    Last Post: 08-07-2008, 09:15 PM
