Results 1 to 10 of 10
Thread: Sanding Sealer
    Sanding Sealer
    A lot of you use sanding sealer for your projects. What brand do you use? Any special reason? What I started to use seems to muddy things up.
    Dennis
    Palm Springs, Ca
    1,169
    You will get alot of good answers but I use several things or methods and it all depends on what im doing but here goes..
    Mixture of Laquer/Laquer thinner 50/50 or a bit more on the thinner - I think it works very well and drys fast so I can keep working on my finish. Sometimes i knock down between coats and alot of times I don't need to and add several coats or more depending on the wood and grain.
    General Finishes makes - Armor Seal - works well also but drys slower - I use multiple coats and knock down lightly in between coats.
    These have become my favorites now but I have tried others and they work fine.........Dan
    Note - One thing i stopped doing was using Danish or Antique oil on the lathe and wet sanding, allowing to dry and let the slurry fill in the pores - the reason is because of the muddy type look even after sanding well - I just dont like the look personally............. but you could apply the above with wet/dry and then clean off very well prior to allowing to dry.......I then use the 50/50 laquer sealer to level things ....then finish with spray on laquer - I do that at time and it also works very nicely...................hope it helps
    Goodland, Kansas
    4,834
    Dennis I use this sanding sealer. It helps with preventing the light woods from darkening so much when using oil finishes. Is a great foundation for lacquer finishes.
    http://www.packardwoodworks.com/Merc...ish-behlen-qss
    Also I have used antique oil for wet sanding but wiped off the excess just before it turns sticky. Never have had a problem with clouding but quit using it as I found it isn't really necessary with a oil finish if you use the above. That is the only sanding sealer I use.
    Bernie W.
    Tellico Plains, Tennessee
    4,353
    Bernie,
    Are you using the SS under the oil? Unless I'm misunderstanding how they work, I would think the oil couldn't penetrate the wood if the SS goes on first...
    I've been using the SS from the local Borg.. don't know the brand off top of my head, then adding the wipe on poly over that... works for me... but I'm always looking for a better way to finish my work... I've seen some finishes on here and at shows that blows the mind. Wouldn't mind getting my work to that level.
    Chuck
    Tellico Plains, TN
    11,834
    I use Myland's because it was reccomended and I have it.
    Goodland, Kansas
    4,834
    Bernie,
    Chuck I use it under the oil. It works with oil, poly and lacquer very well. I think it does stop the oil somewhat if not sanded but I sand it down before applying the oil. It helps keep from darkening the light colored woods.
    Bernie W.
    Kaneohe HI.
    70
    Sanding sealer
    Good topic. I use a lacquer ss. Can you still use a Wipe on Ploy on top of the sealer. The Instructions clearly states not to use polyurethane. Will it still take the finish?
    Nov 2008
    Tampa & NC
    432
    Sanding sealer
    I'v been using a waterbased sanding sealer that I get from Ace hardware and really like the way it works.Sometimes I finish with oil and sometimes I just sand down to about 600 grit,then beal buff and wax.
    IMHO Sanding sealer is not much more thana cheap quick drying finish that soaks in and tgets hard quick, allowing you to sand a slicvk surface and seal off the pores to provide a smoothe surface. Coulld be as ssimple as a Lacquer, Shellac, Oil based quick dryin finish. Secret is the penitrating quick drying characterisitc.
    Sanding sealer is after coloring, but you can do a surface sealer pore filler, etc. after sanding sealer...
    Quote Originally Posted by Bill Simpson View Post
    In over 40 years of woodworking I have never used a sanding sealer. I figure if needs more finish then it needs more finish so I guess you'd say my finish is my sanding sealer. Never had a complaint. My Dad never used it and his Dad never used it.
  1. sanding sealer or lube?
    By hu lowery in forum Finishing School
    Last Post: 05-06-2014, 08:49 AM
  2. Sanding Sealer
    By Philip Miller in forum Finishing School
    Last Post: 11-20-2012, 02:54 PM
  3. Black Walnut need sanding sealer?
    By Bernie Vail in forum General Woodturning Q&A
    Last Post: 12-18-2010, 03:48 PM
  4. Finishing with Sanding Sealer
    By Matt Fritz in forum Site Questions and Test Posts
    Last Post: 12-04-2009, 03:11 PM
  5. bulls eye sanding sealer
    By Chris Mire in forum Finishing School
    Last Post: 12-02-2008, 04:42 AM
